Great deal available for a Xantia V6 or a Xantia TCT Activa owner.
Parts removed from an early RHD Xantia V6 and were accumulated to convert a series 1 RHD TCT Xantia Activa into the ultimate... a RHD Xantia V6 Activa. The conversion is no longer happening and all parts are available here in one package, which will be ideal if you were:
a) thinking of converting your series 1 Activa to V6
b) you have an early V6 Xantia and wish to have parts to keep her on the road for longer (some parts will also be relevant if you have a late V6)
What you get:
V6 Engine
Top Engine Mount
Engine Mount Tie Bar
Coolant Pipes
Coolant header Tank
Manual Gearbox
Gearbox Mount
Clutch
Flywheel
Lower Engine Mount
Starter Motor
Alternator
Engine Wiring Loom
ECU
Air Intake Pipe
Air Filter and bracket
Battery Tray
HP Pump
Pump pipes
PAS pressure Regulator and pipes
Front Strut Feed pipes
LHM tank Piping/Harness
V6 Fuel Feed Hoses
V6 Front Calipers
Exhaust
V6 Handbrake Cable Guides
Steering Rack Heatshield
Cooling Fans and Cowling
V6 Specific Throttle Cable
V6 Pinion Valve
Aircon Compressor
V6 Heater Matrix Connector
If you were doing the V6 Activa conversion you will need to also source:
N/S Driveshaft,
V6 O/S Handbrake cable (buy new)
Front hydractive sphere block
as well as possibly some minor brackets
Offered for sale at only £350.00
The big proviso is that you must, without fail, collect on 29th, July or 30th July... if you can't make those dates then please do not complete the sale. You must also collect everything.
I can offer load out assistance and the use of a crane to load the engine into your vehicle.
Collection from Milton Keynes, MK16
Please only respond below if you are interested in purchasing the items and have genuine questions, I'd like to keep this thread on topic, thank you.
(If you are wondering, these parts were originally offered on here in May 2016 but the previous party has now confirmed that due to personal circumstances they will be unable to collect and therefore complete the transaction).
Terms of the sale:
- The buyer must collect all items on the afternoon of Saturday, 29th July (after 12) or Sunday, 30th July, please choose one of these days as both aren't available
- If you fail to collect the parts will be moved into paid storage and charges will apply, sorry need these parts moved!
V6 Xantia parts deal! Package parts deal!!!!!!
DS21
Re: V6 Xantia parts deal! Package parts deal!!!!!!
Forgot to mention that there is a new V6 cambelt kit included... this is a stonking deal!!
- x 5674
Please post any responses in the thread in For Sale And Wanted
