The Boxxer is rapidly going through os headlamp bulbs. I suspected a poor earth so I removed the entire headlamp to check. It doesn't appear to use body/chassis earth at all. Theres only one cable iI can't trace as I'd have to take the bumper off but i don't believe it is an Earth. Connections are both clean and secure.
Any ideas or should I just add it to the sliding door repair when it goes to the garage next werk?
Bulb eating Boxxer
Re: Bulb eating Boxxer
For a minute there I thought you were talking about your dog and tulips.
elma
- x 284
- x 1240
The only things which will normally make bulbs fail is excessive voltage and vibration, over volts would cause others to fail as well so you can probably rule that out. Are you replacing the bulbs with the same make every time? If so I would suggest you have a duff batch of bulbs. I always use 'Ring' bulbs from ebay, they are very cheap and very good.
- x 8411
Don't overlook earths... My 207 used to eat bulbs for breakfast and all sorts of electrical 'funnies' going on - which is why it became mine...
I found the earth bond from the battery to the bodyshell was decidedly suspect. Cleaned that up and never a problem since - touch-wood.
Trace your negative lead from the battery. It'll end up on the bodyshell somewhere and then dice off to the gearbox...
Give the bodyshell earth point a good clean and reassemble...
- x 1746
Jim is dead right with earth-checking. The alternator relies on a good ground connection for its internal voltage regulator to work correctly, If it doesn't, system voltages can surge or 'flare' as indifferent connections come and go.
PSA grounding and battery connections have a long history of degradation over time. Check that any bodywork bolt-down earths don't have original paint (!) on their contact surfaces.
elma
- x 284
Im going to leave it to the garage. Peugeot have built the boxxer appallingly as far as ease of maintenance goes. I expect a lot of the front end needs to come apart to trace the wire. Its had all sorts of different bulbs and the current one looks ok but doesnt light up. Last thing I'm going to do is check voltage then over to the garage. Got to work both days this weekend as we still don't have irrigation and its boiling. Not really in the mood for wasting time on the van.
