On my walk.
ekjdm14
x 263
Re: On my walk.
Unread post by ekjdm14 »
So the window was left down intentionally with a view to reconnecting the battery properly? how's the interior cleaned up, have you given it a scrub?
Be a shame if you can't find a box
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
x 2941
Re: On my walk.
I gave the exterior a shampoo and vacuumed the interior, did the dash and interior trim with those trim wet wipe things and it looks pretty good.
When I connected the battery (£20 from the local breaker) everything came to life., the tailgate window opened and the headlamps came on.
It's fairly high spec, has ESP and cruise control.
Needs tyres, they're mostly at the limit although a couple would pass and as I said in a previous post the original spare has never been on.
x 8391
Re: On my walk.
I wonder if a manual gearbox conversion might be possible or economic?
x 2941
Re: On my walk.
I have considered it Jim but I doubt it's worth the effort, I did one on a Hillman Minx years ago (Smiths Easydrive) that was bad enough.
One thing I've noticed is how easy it is to get this auto box out compared to the manual box, looks a doddle.
Harlequin
x 24
Re: On my walk.
Unread post by Harlequin »
The autobox fitted to another PSA brand?
x 1943
Re: On my walk.
Gibbo2286 wrote: 04 Jul 2017, 12:58... the tailgate window opened ...
That's a rarity in itself. Got to add another £200 to any asking price! :rofl2:
x 3306
Re: On my walk.
Paul-R wrote: 04 Jul 2017, 14:03
It opens on my Mk1 C5!
Harlequin
x 24
Re: On my walk.
^^ that's because you fixed it :P
x 3306
Re: On my walk.
Well, I did have to buy a replacement switch, but it did open before then (sometimes on its' own when a different door was opened or closed!).
x 2941
Re: On my walk.
Harlequin wrote: 04 Jul 2017, 13:46 The autobox fitted to another PSA brand?
No, I've been through the whole list of vehicles and part numbers none match, there are a couple of Vauxhalls with a look alike box but the ratios are different, the C5 2.2 HDI same year has a ZF box.
x 2941
Re: On my walk.
Hell Razor5543 wrote: 04 Jul 2017, 15:55 Well, I did have to buy a replacement switch, but it did open before then (sometimes on its' own when a different door was opened or closed!).
I noticed this one did something similar, the tailgate was open a touch, I opened one of the rear doors and the tailgate window popped open.
x 3306
Re: On my walk.
Gibbo2286 wrote: 04 Jul 2017, 16:45
On my switch the wiring showed distinct signs of water damage (the insulation was OK, but the copper was blackened). When I replaced the switch (around £40 from Peugeot) the tailgate behaved properly.
demag
x 102
Re: On my walk.
Unread post by demag »
Mine doesn't open although it's a minor detail.
Dave
x 2941
Re: On my walk.
I found and bought a gearbox :shock: so now I'm committed (or ought to be :) ) to putting the car back in running order., box due to arrive Wednesday, second hand from a car with around the same mileage but claimed to be in good working order.
The mechanical stuff is pretty straightforward but I might need some help from you guys when it comes to 'Initialise the ECUs following the instructions on the diagnostic tool.' I've got the tool but never yet used it.
The whole project is a huge gamble but........................
x 8391
Re: On my walk.
Excellent :D I shall follow the project with great interest Gibbo ;)
