Would i be right in adding the latest spec Dot 5.1 fluid into the pot as over the years i have lost possibly up to 50ml plus dribbling very slowly onto the clutch pedal, or should i put in what was used when the car was new back in 2001 so would that be Dot 3 or 4 or does it not make no difference if i add 5.1, dont want to make matters worse by adding wrong Dot..
Xantia 110 hdi clutch/brake fluid
xantiagreen
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
elma
- x 284
Re: Xantia 110 hdi clutch/brake fluid
I don't think they are compatible.
Probably best to use what it says on the cap or in the handbook.
- x 5689
davoxx
- x 15
err doesn't an xantia use lhm for it's clutch/brake fluid?
why?
elma
- x 284
110 is hydraulic clutch.
Brakes are hydropneumatic LHM as you say.
davoxx
- x 15
good to know, I've never had to fill a clutch on an xantia, but now I know it uses brake fluid.
why?
elma
- x 284
Most Xantia are cable clutches. Just the 110 on the diesels is hydraulic. The petrols I don't know as I've never had any except my current one which is an auto.
