Discontinuation of Tapatalk Support
Forum News, Announcements and any issues you're having with the forum
superloopy
x 19
Re: Discontinuation of Tapatalk Support
Unread post by superloopy »
Jim ... i have no intention of running an aged laptop, linux or otherwise. I joined the forum some years ago when mobile phones were in their infancy, certainly not the sophisticated choice of internet device they have now become. In those days pc access was common. But things move on. Since TT came along i find it a lot easier to read and post. Its ability to collect everything i want to see and present it in s consistent manner across multiple forums on a daily basis is a godsend. I certainly wont be moving away from it. As i say i'll just become an occasional 'lurker', a 'guest' as the forum identifies those people. Not an active member but able to use the wealth of knowledge only as i need it, 'selfishly' as a previous poster commented. Certainly i wont be actively reading all posts which i do now. I see my level of interest dwindling even further and still consider the imposition, for that is what it is, an unnecessary restriction. Others can continue to access as they wish but i can guarantee as sure as night follows day that further changes will come thick and fast. Power breeds power and some people revel in it. Not me, i've always resisted egoistic change as far as possible. In this case the 'ego' i refer to can have his way and i'll lurk as a non-active observer once more when the change is implemented. I say 'when' because as we've all been primed with 'this non negotiable'.
Sent from my LG-D855 using Tapatalk
Mike
ekjdm14
x 256
Unread post by ekjdm14 »
Why even bother to observe, if it's going to be that much of a pain to access though? surely you wouldn't put yourself through the endless hassle and ballache of laboriously slogging your way onto the site through one of the other clunky, inefficient and overcomplicated means of access, only to finally get on here and merely look?
That, surely, is even more backward than discontinuing tapatalk support might seem to some.
One thing I think we'll both agree on is there are some big egos on this forum ;)
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
x 1438
Unread post by xantia_v6 »
For those who find that the forum font size is inconveniently small, particularly when using a phone, I have installed an extension for testing on our test server.
Given the interest here, I am inviting a public trial. The test server is located at: https://xantiav6.co.uk/forum and is currently running a snapshot of this forum's contents from a few weeks ago. You can browse or post on the test forum, but anything you post will be wiped in a few days.
If you log into https://xantiav6.co.uk/forum/ fonts and spacings should normally be the same as this forum (although a few are wrong at present). If you go into your user control panel and the tab "Board Preferences", you will see a new setting: "Would you prefer the font to be larger?:" If you select that, then the fonts on the main forum pages should get about 20% bigger.
Please try that if you are interested and let us know if it helps at all.
For those who don't want to try it, here are some screen shots:
GiveMeABreak wrote:Works a treat Mike:
I don't need my glasses now! This changed from the UCP using the options. Clicking these pics will give a better image quality as you know, just so you can see that it is a better picture than as displayed.
superloopy
x 19
Re: RE: Re: Discontinuation of Tapatalk Support
ekjdm14 wrote:Why even bother to observe, if it's going to be that much of a pain to access though? surely you wouldn't put yourself through the endless hassle and ballache of laboriously slogging your way onto the site through one of the other clunky, inefficient and overcomplicated means of access, only to finally get on here and merely look?
I think you'll find that 'lurkers' form the majority of activity on the forum these days. It has shrunk in activity since the heady days of some 2-3 years ago. I suggesst that those who have either left altogether or no longer contribute so profusely is down to a change in forum direction and management. Maybe, just maybe, they didnt find it to their liking and chose to move on without kicking back. Or ... maybe they just dont own a citroen marque anymore [emoji39] Certainly numbers are dwindling.
Mike
x 8291
xantiamanic wrote:Jim ... i have no intention of running an aged laptop, linux or otherwise.
Fair enough Mike, just trying to offer a suggestion. I shall say nothing more on the subject...
ekjdm14
x 256
xantiamanic wrote: I think you'll find that 'lurkers' form the majority of activity on the forum these days.
Indeed, and I did not say otherwise. It's the case with many fora these days, most people seem to have moved over to "pages" on Facebook for active chat etc. My point was just that if it's that hard to log in and post via media other than tapatalk then surely it's just as bad trying to get on just to look. In other words, if you can make it as far as viewing the forum why not contribute also, if you have something relevant to add?
As for the direction the forum has taken the last few years I'm ill equipped to comment, having joined just over 2 years ago, but I will say that I've not had a problem with the "management" since I've been here & indeed find the way the forum is run a lot better than many.
Indeed when the recent "facelift" was questioned by members it was reverted, put to a vote, and voted against thus has stayed how it was. I agree that consultation prior to implementation would perhaps have been a better way of doing things there, but ultimately admin listened to the membership who had an opinion to voice & acted on the feedback received.
I can't see things being much fairer than that really, and it can't have been easy to effectively "throw away" the work that had gone into creating the facelifted site...
Of course your opinion and that of other, prominent members differs to mine and in such cases I feel we're not likely to ever agree fully so I think this will be my last comment on the matter also.
superloopy
x 19
Re: RE: Re: RE: Re: Discontinuation of Tapatalk Support
My point exactly ... it is a backward, retrograde means of accessing a forum, esoecually when a tool exists to make life so much easier. Moreso when multiple forums, fora, are being contributed to also. Shame really that you only joined fairly recently otherwise i'm sure your opinion on management would've been even more praising. I have nothing but disdain for some of our current management and their seemingly self promoting interest in the forum. Was never the case until recently. Just one big happy family rolling along in peace and harmony [emoji3][emoji3][emoji3]. Look at us now.
As for 'throwing away' earlier work by some admins being a difficult thing to do, you miss the fundamental point in all of this. Admin needs to talk to the membership BEFORE attempting to change the forums direction. Had they (?) consulted prior to trying to dictate a forum facelift they would' ve saved themselves an awful lot of time and effort. However i doubt that that work has been 'thrown away'. It will resurface in the not to distant future when all of the objectors have been purged.
Mike
x 1920
xantiamanic wrote:Admin needs to talk to the membership BEFORE attempting to change the forums direction.
There is an element of truth there. Perhaps if it had been presented as "Look, there's a problem with Tapatalk that we can't se a way around. [...explain what the problem is...]. Unless anyone has any clever answer we can't see any alternative but to discontinue support." and then give a couple of weeks or so for discussion.
It's surprising how many people can be carried along if they've had a say in talking it through even though they might be against the idea.
x 6954
That's why this announcement was put up Paul - posted by me, but agreed collectively by the team. Tapatalk is a law unto itself and is not something we can 'modify'. Aesthetic / cosmetic changes are one thing, but issues of security are not really up for democratic majority decision.
x 3295
The problem is (as I see it) NOT that Tapatalk support is being discontinued by the forum, but that the way it was presented was (in effect) a fait accompli (this IS going to happen). In the past, when there has been a problem, the moderators have (as far as I can recall) clearly explained what the problem is, what they have done (or can do) to resolve it (sometimes they have asked for assistance from forum members), and (on any occasion when they have NOT been able to resolve the problem) clearly said so.
I am NOT a Tapatalk user, so I cannot see WHAT the problem is (other than what has been explained here). I have offered a suggestion, but I accept that this does not appear to be viable (for reasons that are, in some part, beyond the control of the moderators). I would make a different suggestion, in that the moderators delay the implementation of the update that will kill off Tapatalk support while working with those members who will be affected to see how to implement a way for them to easily be able to access the forum from any reasonably current smartphone.
As things are there are several members who seem to be feeling that they are being punished for using a communication system that, to them at least, is viable, but does appear to have security issues and loopholes that allows the software house access to the forum that they would not normally be allowed access to.
This forum has been described as "the friendly English Country Pub, where everybody can come in and chat". I certainly have represented it as such. However, currently it seems that one (or more) of the landlords has said something like "For hygiene reasons it is no longer possible for the drinkers to have their own personal and individual drinking tankards" without clearly explaining what, if any, options there are (such as standard tankards but with names engraved on them). This will sour the atmosphere, and could drive away some of the clientele.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Personally I'll be glad to see the back of Tapatalk as it will no longer keep popping up like spam when I go on the forum, so whilst some loved it others like me found it a complete PITA but worked around it for the benefit of others who used it, now that's no longer the case it's time for a swap in roles.
As for the number of members reducing I think that's easily explained by the fact that the gist of this forum has been hydraulic Citroens which are becoming fewer by the day plus members like me have moved onto other cars so the amount of discussion will inevitably reduce, not to mention that everything that anybody could reasonably do with a BX or Xantia has been done many times over plus C5's are few and far between so I'm not in any way surprised by this.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1920
I don't like to carp but there's been a change (this afternoon I think) to the layout which has reduced the number of items on the page list. I don't know if this as a result of changing the font size for mobiles/pads (I'm using my laptop at home now) or what but it's a pain as it means more scrolling down to see the titles of the posts/subjects.
I'm all in favour of the creative use of white space but this is just annoying. It's very much like a lot of "modern" sites which require page after page of scrolling down. I don't like them either.
x 1920
This is what I mean.
Can I have the old version back please?
x 1751
Not changed for me (even after a reload). Still getting 50 items per page, on both PC and iPad.
x 6954
Are you sure you're not still on the test server link? There's been no change on the live Forum regarding display.
