I need a part number
Nemo26
x 4
Unread post by Nemo26 »
Hi, to all forum members.
I am a hobby mechanic, from Croatia.
I have had a problem with watter in car, and during repair I broke plastic clips (2 and 3 in picture) from roof. Now i cant find part nr to order new one. Does anybody here can help me? Thanks a lot.
hd host images
x 6957
Re: I need a part number
Post or PM your VIN so I can check the correct parts for you, as you haven't said what Spec., Year, Saloon or Tourer.
Not to worry - I've found it's for the saloon roof trims. As you have probably already guessed there are no parts listed for the clips - so either they would come part of a new moulding or you will have to ask Citroen directly as in the documentation it does recommend replacing them if they are damaged on removal - so they must be available.
Nemo26
x 4
x 6957
As per my last post - no parts for the clips referred to in the repair procedure - 6 & 7 are only the fixing screws and nut caps - so as I said, I think you'll need to speak directly to Citroen for these.
C5 X7 Roof Panel
C5 X7 Roof Panel
Nemo26
x 4
I spoke already but they told me that there are no reserve clips only, but in service box there is remark: in case that clips are broken, replace with new clips???
I didn't saw your last post :-D
x 6957
Yes, they do mention them as replaceable, but that could also mean only as part of a new trim piece!
They do for example make the windscreen plastic clips available - as of course they need to replace these under the side pillar trim when the windscreen is replaced - and they would sell a lot of these to the windscreen companies - but in this case for the roof trim - you might be stuck with having to buy the trim and then trying to use or rescue the clips off the new trim to use on your old trim, as you won't want to be painting it too! :-D
Nemo26
x 4
Then I'll have to buy another one I'm afraid.
Poslano sa mog JY-S3 koriste?i Tapatalk
x 6957
It might be the case, but check with the main dealer first to double check that they are supplied with the trims. Have you tried finding a donor car that's been written-off by the insurers after an accident?
Nemo26
x 4
I didn't check for donor car, but it's very difficult to take off this clips undamaged.
x 6957
I've just checked the price in the UK and each trim is £101.09 excluding 20% VAT (£121.31 Inc. VAT) and that is unpainted. So I expect a similar amount in Germany.
Nemo26
x 4
For unpainted trim it's very expensive. I just bought lexia, my wife will kill me [emoji1] [emoji1]
x 6957
:rofl2: Better wait till next month then! :-D
Nemo26
x 4
Of course, she doesn't want to hear about car this month [emoji1]
Saraphee
x 11
Unread post by Saraphee »
Google "LCS Louth eBay Stores"
They had the clips for my Citroen ZX roof trim.
Nemo26
x 4
I contacted them and unfortunately they don't have it.
