x 8400
Re: I am an Activa owner...a V6 and I am an addict
Stickyfinger wrote:I cannot seem to find the bush as a "part" Jim, just the whole mount including bush.
Ahh, in that case. not available as a separate part then unless one of the polybush companies have made something suitable or are prepared to..
Last time I spoke to one of the well-known suppliers of such items they were totally uninterested...
Might have to end up making one out of a suitable material as I have with ram bushes in the past...
Unless a 1.9TD one will fit and they are/were available as I have one...
Can you get the dimensions and I can then check...
Good bodge on the door trim :evil:
x 3296
I have a few hog rings (that I got from Citroen to fix a door trim in place) that were for an S2 Xantia (stock code 8565 35, IIRC), if a few of those would help. However, they are also readily available on e-bay.
x 1996
Unread post by Stickyfinger »
Hell Razor5543 wrote:I have a few hog rings (that I got from Citroen to fix a door trim in place) that were for an S2 Xantia (stock code 8565 35, IIRC), if a few of those would help. However, they are also readily available on e-bay.
All done thanks mate :)
x 1996
I still have to remove it from the engine in the garage Jim.......I bet there will be a suitable bush out there.........
demag
x 102
Unread post by demag »
Ooh that trim looks nice.
Dave
x 1996
demag wrote:Ooh that trim looks nice.
Rod for my own back.....gotto take the others off now and wet flat/polish them as well :(....I am such an idiot !
x 8400
I agree, I think glossy contrasting side strips look absolutely gorgeous 8-)
If you have the mount off by Friday I could bring a 1.9TD bush down with me and then we can properly compare the two and see if it'll fit the V6...
x 1996
Will do Jim.....
x 1996
Well I now have a solution for adding additional cold air cooling for my brakes...............
A set of "micro" fog lamps will be added in the corners of the lower grill
After a mix up with a set (size) of Brembo grooved disks I have been looking at the advantages of solid vented disks but with additional cold air cooling. I have concluded there is a larger advantage with a good flow of additional air over no air but groves/drilled. I will thus try this method before adding grooved disks and see how it goes.
superloopy
x 19
Unread post by superloopy »
You beat me to them [emoji53]
Sent from my LG-D855 using Tapatalk
Mike
x 8400
I like those fog lamps Alasdair... Never seen them before...
superloopy
x 19
Yeah .. they look like a set for early S1s to me. Both my S1s already have foglamps so i didnt really need this pair, Sticky obviously did cos he bid right up to the auction end time [emoji14]
Mike
x 1996
2 second snipe mate.............:)
As said, it is a solution to cooling.
I also had never seen these before, they will make the modification look very standard when painted to match the bumper hence me being keen.
x 1996
Oh yes....
|Guess what passed its MoT ...ZERO advisers....record of MoT's still clean for every car taken in :)
x 8400
Stickyfinger wrote:Oh yes....
Brilliant result Alasdair :D =D>
