- x 1463
Re: I am an Activa owner...a V6 and I am an addict
I have not done a lower mount, but I would have thought that it would be easier to make a mandrel and spacers with a through-bolt to press it out in-situe? The outer steel ring on the bush is cut into segments, so it is only the force of the rubber holding it in.
- x 8410
Not as I read it Alasdair but I stand by my earlier statement...
Upon re-reading them Mike's words can be interpreted in different ways - or at least I did...
I'm not even sure the tangle of exhausts in the area would even allow you to do it. Even getting at the 'hockey sticks' to release the driveshaft intermediate bearing on a V6 is a bit of a mission compared to other Xantias... The bush and bracket is well hemmed in...
And remember the bush is in there bloody tightly, it isn't just going to fall out or come out easily... And nor will the new one go in easily...
- x 1463
A couple of points...
The item pictured on the previous page is the (NFP) upper mount, not the lower. The picture is of the underside, which threw me at first.
The lower mount sits below the driveshaft, and in front of the subframe so is fairly easy to access.
- x 1994
Are...OK, will need to go look again then....my bad chaps and sorry for the confusion from me.
- x 8410
Mike, well spotted on the mount being the top one and not the lower one!!! I feel very embarrassed I did not see it...
Time for new glasses
- x 1994
The middle one ?
- x 8410
None of the above Alasdair...
- x 8410
It's the one not shown...
- x 1994
Ummm.......Ahhh!....It must be on the engine then ( I hope)...off to look.
edit:
Yep it is there...a big housing 3/4 covered by the drive shaft "cup"
edit:
- x 8410
Did you save the one from the GG Alasdair?
- x 1994
Yes, the engine in my garage is from the GG Jim.
- x 8410
- x 1994
I had a visitor today, Daffodil came for new spark plug leads and a snow foam wash and polish......
Changed the oil in the Activa
- x 8410
She's looking good Alasdair
Has Daffodil had any reoccurrences of her power losses?
- x 1994
Yes, but changed the spark plug leads today. As they are the last thing (except the coil pack) that needed changing I hope that has cured it.
