The "shop" selects these for the V6......so that is wrong as they are 266mm ones. I will have to return them
- x 1997
Re: I am an Activa owner...a V6 and I am an addict
Oops.....disks are wrong for the v6.....rats.
sadface !
- x 1997
MOT @ 4pm today.......gulp (I always do)
MikeT
- x 232
Good luck Alasdair!
OnlineHell Razor5543
- x 3296
You don't need luck, Alasdair, not with the way you look after your vehicles.
- x 8422
Stickyfinger wrote:MOT @ 4pm today.......gulp (I always do)
You'll be fine Alasdair, and so will the car... I do fully understand though... I'm exactly the same, if not a lot worse...
That's a bugger on those discs
- x 1997
My "Stupid" Jim for not checking that their site throws up non suitable recommendations.
- x 1997
MoT PASS with zero advisories, my clean record with all my cars is maintained....phew.
- x 8422
Alasdair, that's fantastic news
Mind you, I never doubted that would be the result of your MOT for a split-picosecond
- x 1997
I did see a lower engine mount that I am not "happy" with however, the MoT tester laughed at me and said "that is fine np".
I would like to change it however
What is the job like on a V.6 ?
- x 1997
It seems that the Green Goblin had a new lower engine mount just before I scrapped her....result
- x 8422
Now that is a lovely result Alasdair... Excellent
One thing worth knowing if this is the same one as used in a 1.9TD and other XU engine Xantias, especially the TCT Activa...
- x 1997
Nice to have an OEM one in a new bracket, save faffing about pressing in cheap ones
- x 1471
I am pretty sure that the lower mount is the same as the other PSA engines.
I think that it will be a LOT easier to change if you take it out of the bracket and just change the bush.
- x 8422
xantia_v6 wrote:I am pretty sure that the lower mount is the same as the other PSA engines.
That's good to know Mike
I quite agree, already expressed this view to Alasdair outside the forum!xantia_v6 wrote:I think that it will be a LOT easier to change if you take it out of the bracket and just change the bush.
I'd certainly not faff about trying to do it in-situ - I know how tight these are in the housing... Removing the driveshaft is a price to pay to do the job easily, safely and being able to use a bench press...
Generally, so often and in many cases, a little more dismantling and doing the job on the bench can be so much easier - and quicker! - than struggling in-situ...
- x 1997
Is Mike not saying it is easier to do ON the car Jim ?
