Hi, wondering if anyone knows what this issue could be my picasso has a fan fault, when I unlock the doors of my picasso, the radiator fan turns on and stays on until the car is locked again when it turns off after about 15 mins, there are no fault codes, no dash warnings but this dreaded fan that stays on and ultimately drains the battery.
Any ideas on potential faults please?
2010 C4 Grand Picasso radiator fan fault
- x 6955
Re: 2010 C4 Grand Picasso radiator fan fault
Hi and welcome to the Forum. Assuming this is a diesel , it could be that your vehicle was in the middle of a Diesel Particulate Filter Regeneration cycle when you switched the car ff and it does this to cool everything down as there is a lot of additional heat generated during a regeneration. If it doesn't complete the cycle (i.e. you switch the vehcile off again before it has had time to complete, then it will try and regenerate next time and the same thing may happen. Best thing is to take it for a good spin at a constant speed and keep it out of 6th gear if poss. for a good 20-30 mins to give the engine time to warm up and then regenerate. Short journeys are not good for diesels.
Bsgti
THanks for the response, I'll give this a try tonight and get back to you,
Would water in the engine fuse box cause this issue? I've seen a few posts suggesting this may happen?
Bsgti
Hi, cheers for the welcome, been a French car person for a while now, c3 vtr, renault Clio 182 cup, c4, Picasso and now luckily a 208 gti, by far the worst car was the 182, had so many issues it was getting a joke, the picasso in 7 years of ownership this is he only major issue I've had (apart from 3 replacement boot locks where the micro switch fails)
- x 6955
Well that of course won't help anyBsgti wrote:THanks for the response, I'll give this a try tonight and get back to you,
- x 1484
Assuming this has happened more than once, then I would suspect a fault with the fuse box, the temp sensor, or the fan unit. You will get a message on the screen if it fails the regen more than a couple of times. I had to put a new fan on ours because it was squealing. IIRC there is a small ECU on the fan itself, but I might be making that up! As there's no temp gauge on the C4 Pic, you can't tell if it thinks the engine is too hot - you would need a Lexia for this.
Bsgti
Thanks for the reply, yes been running now for over two weeks and we've had a few people out but none have the required software to fix, anyone know of any mobile mechanics with lexia in Chatham maritime? I could go to?
jgra1
- (Donor 2021)
- x 36
I could come out .. it's a fair drive for me, but my lexia works on my 2010 c5.. I would need to charge as I am unemployed
John
John
- x 1484
What engine is in it? I'll see if I can find a wiring diagram - you may be able to check the pin out on the fuse box to see what it's up to.
Bsgti
It's a 1.6 hdi 16
John, thanks for the kind offer, would be willing to pay for someone to fault find, but your probably too far away, don't want to make forum members drive halfway across the county to help me, but thanks anyway
Bsgti
Can't quite work this one out, the original battery was charged up at the weekend, and again the battery went flat over one night (only used it once and the fan was on 15 mins)
So I changed the old battery (7 years old) for a new one, doors open and fan comes on, stop, fan stilll on, next trip, fan on, hen locked the doors and the fan turned off!
Cue going out a few hours later unlock the door, NO FAN???? Drive to location stop, and fan switched off?
Confused now the issue seems to have cleared, or am I hinting it could have been a battery issue!
- x 5653
It does rather look like the battery was kippered.
Try giving it a full charge then checking periodically with a voltmeter to see how it performs.
I imagine one or more of the cells have collapsed.
Bsgti
Ah too late it gone to the big battery store in the sky.
I'll keep all informed if the issue returns, cheers.
