Hi
I tried to remove the glove box in my C4 ( Make year 2009 ). To remove it, I removed the torx head screws around the outside edge, then remove the hidden one under the 'air bag' sticker. Then I tried to pull it out, but I can't , I felt that it is still attached in the bottom of the glove box to the dashboard. Are there any other hidden screws ?
The car is LHD
C4 - Glove box removal
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 6950
Re: C4 - Glove box removal
PM or post up your VIN and I'll take a look for you.
lancia58
- x 8
Re: C4 - Glove box removal - removed
I removed the glovebox, it turned out that the lid's hinges are attached to the dashboard and one has to apply some force to detach the hinges.
Zohar
Zohar
- x 6950
No problem, glad the docs helped.
