Diagbox/Lexia versions...update beneficial for 2005 C5 II?
AlvinCitroenC5
x 3
Unread post by AlvinCitroenC5 »
Hi,
I have just installed the Lexia / Diagbox software onto my computer. I have purchased the Diagbox / Lexia / Pp2000 tool for my 2005 Citroen C5 II 3.0 V6. Insofar I have upgraded the software to Version 7.49, and can see my vehicle in the list. However, I have newer versions which I can upgrade to, is it necessary? If the 7.49 has everything I need, I will just stop upgrading to the highest version which I have obtained.
Thank you.
x 3302
Re: Diagbox/Lexia versions...update beneficial for 2005 C5 II?
Do NOT upgrade past 7.57! Apparently PSA are trying to gain more control over the DiagBox software, and later versions have to connect to them for some on-line functions.
I have used 7.15 on a C5 X7 (setting up DRLs), so I would say you are OK with the version you are running.
AlvinCitroenC5
x 3
Thank you very much!
