Window blind catch / hook
hoggers
x 11
Unread post by hoggers »
This just snapped off. Could someone be kind enough to give me the part number?
Looks like it's come off before and someone has just glued it back on [emoji35]
Sent from my iPhone using Tapatalk
elma
x 287
Re: Window blind catch / hook
Unread post by elma »
Stick your vin number up please or it'll be harder to look up the correct part.
x 5582
Gorilla glue?
hoggers
x 11
x 6956
hoggers wrote:VF7**************[VIN obfuscated, can be read by forum staff]
Looks like your rear passenger side window blind catch from the pictures Ben. If so, part is: 7467 HT and is called a Sun Visor Catch, and is £13.64 Inc. VAT :-D
Now that is one expensive piece of plastic I have to admit!
hoggers
x 11
Jeeze! Breakers yard it is!
ekjdm14
x 250
Unread post by ekjdm14 »
£13.64 for that? Not surprised someone's glued it before! Either gorilla glue or find one in a breakers would be my choice.
Edit- yep
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
hoggers
x 11
ekjdm14 wrote:£13.64 for that? Not surprised someone's glued it before! Either gorilla glue or find one in a breakers would be my choice.
Edit- yep
Tried gorilla glue and so far so good [emoji1303]
x 6956
Haven't actually used Gorilla glue, but many seem to rave about it. Now added to the shopping list!
hoggers
x 11
GiveMeABreak wrote:Haven't actually used Gorilla glue, but many seem to rave about it. Now added to the shopping list!
Yeah very impressed. Got some on my fingers and bricked myself that I wouldn't be able to get it off as it set so quick.
x 6956
Good point, I'd better add some thinners too!
ekjdm14
x 250
The 2 part epoxy of the same brand is pretty good too, it's that which was responsible for the 3 cylinder XUD making oil pressure (blocking the "dead" journal's holes) and is also doing a good job holding some bike bodywork together that was damaged by "Doris" the storm...
mickeymoon
Unread post by mickeymoon »
I've got loads of stuff repaired with the 2 part epoxy! Great stuff, much better than araldite
x 6956
Crikey, that stuff sounds as if it's stronger than my industrial strength coffee!
ekjdm14
x 250
GiveMeABreak wrote:Crikey, that stuff sounds as if it's stronger than my industrial strength coffee!
Yours and mine both... In fact this thread has given me a thought, if my bottom hose stub does turn out to be cracked I may use it for that temporarily. It's that solid I'd trust it in that application.
