Renault Megane MK1 Engine Cooling Fan Help
This is the Forum for all your Renault Technical Questions, Problems or Advice.
meganeman
Unread post by meganeman »
Good evening folks, I recently purchase a Renault Megane MK1 2001 the only known fault is the engine fan not kicking in when it should do. Does anyone have any suggestions on what the problem could be? Could it be a faulty fuse or engine temperature sensor? Any help would be appreciated, Thanks. :-D
x 1476
Re: Renault Megane MK1 Engine Cooling Fan Help
Unread post by xantia_v6 »
Does the car have A/C?
meganeman
No the car does not have Air Con, just heaters. Got a few days off work so will be having a look at the fuses underneath the steering wheel, could it be something as simple as a bust fuse causing the fan not to work? Sorry if this question is stupid but im clueless when it comes to cars but want to learn about them
x 2006
Unread post by Stickyfinger »
Hi
Not in anyway do I know your car, but I suspect the Engine Fan fuses are more likely in the Engine bay fuse box ?
meganeman
Hi Thanks for the heads up, that would have stumped me if i'd have not known
x 2006
If a fuse has blown in a high amp circuit then there normally is a reason.
When you say "not kicking in when is should"....does it come on at all or do you think it is taking to long ?
