x 1996
Re: I am an Activa owner...a V6 and I am an addict
Unread post by Stickyfinger »
It works on pipes because the overlapping surface contact area is so large, it is also a filler free plastic. Edge to edge on a fairing ? there are better products out there such as the flexible fillers and "hot wire" staples for strength.
x 1996
Well, I used copper filled RTV (locktight) sealant and have used rivets to compress the two parts of the Header Tank together, it is now baking in the "warming oven" of the Rayburn to cure.
I took some time to throw some quick gloss coats over the "faux" wood paint effect on the instalment(s) binnacle I have been wasting time with :)
x 3296
That binnacle does benefit from that effect.
x 1996
1x Cooked, cured and riveted header tank. I will leave it 24 hours and pressure test with hot water tomorrow.
superloopy
x 19
Unread post by superloopy »
Looking promising Sticky ... I ordered up a couple of spares and one of them came with a broken top spigot pipe. Where it went is anyones guess. Do you think this is fixable?
Sent from my LG-D855 using Tapatalk
Mike
x 1996
Just the little (one of) pipes ? Can you insert thin wall copper pipe in and use a Polyvinyl adhesive/high temp/full "hard set" to seal that to the tank ?
x 695
Unread post by Mandrake »
Stickyfinger wrote:Inside a V6 expansion tank:
What is the purpose of that complicated piece of grey plastic in the middle of the expansion chamber ? I've always wondered what it is for. It can't just be a level guide, as it doesn't even do that job very well!
x 3296
Baffles?
x 1996
My bet is both bubble reduction and baffles to allow the fitment of the water level sensor (that is not wired correctly by the factor :) )
x 5673
Hell Razor5543 wrote:Baffles?
Baffles me too James.
x 1996
I had better get up......spring has sphered & it is warm out, best stick my nose out and have a look about .
x 8403
Lovely picture Alasdair :)
x 1996
It yawned, farted some garlic and demanded a coffee and a Gauloises
x 8403
Stickyfinger wrote:It yawned, farted some garlic and demanded a coffee and a Gauloises
Typical French!!! :lol:
x 3296
Not quite typical. It forgot to ask for a cognac as well!
