C5 X7 2-in-1 navigation tutorial
This section is for General Enquiries or for Systems not Covered Above
x 6959
Re: C5 X7 2-in-1 navigation tutorial
a61675 wrote:Hi, Is it possibel to do a switch from RD4 to RT6? And is there a big diff. between RNEG and RT6.
THX for your Guide/tutorial... Very helpful. Martin, Denmark
Assuming this is for your C5 X7 then the upgrade is possible - but you will have to source the extra kit as per the post. It is a completely different system, with the e-myway having the mapping and jukebox data on an internal Hard Disk, whereas the MyWay had the maps on an SD card for example. You will need to purchase the correct screen (beware - there were 2 types, one is a higher resolution and used in the NG4 too). You'll need the fascia replacement (again read the post - there are differences in the sizes for the display screen). It will all need configuring properly too and toe correct options setting to work.
Xantippa
x 29
Unread post by Xantippa »
Does RT6 show artist, album and so on with latest firmware when streaming music from smartphone?
x 6959
You should get the artist and track info, but no album artwork.
szymon189
Unread post by szymon189 »
Hi
Updated from this:
to this:
and it works (THNX) but watched the wideo about hiden menu and i saw this:
My menu looks like this:
How can I activate those other options?
Citroen C5 2012
x 6959
The menu on your last picture is the correct one for normal use. The other menu in the third picture is really just for diagnostic information and changing some frequencies and other settings. Changing anything there can brick your system if you don't know what you're doing. You access it by pressing the setup button once, then pressing buttons 1, 2 & 3 together, then letting go and then wait for the service menu to appear.
But be careful - as I said, there are no 'customer' options to set - everything is set at the factory.
szymon189
GiveMeABreak wrote:You access it by pressing the setup button once, then pressing buttons 1, 2 & 3 together, then letting go and then wait for the service menu to appear.
After doing this I have:
Where do you change your language here?
x 6959
You don't! This one is not the menu to make changes as I said. You need to go back to the proper menu. Just press 'Setup' once and then select languages from the options displayed, then choose your language.
x 6959
If you can't see the menu from a short press on SETUP, then try holding the SETUP button until the other menu is displayed.
szymon189
This is my menu after pressing SETUP
x 6959
Ok, press escape to come out of that menu. When it's back to the radio or whatever, hold down SETUP for 5 to 10 seconds then let go to get the extra menu
szymon189
Click button SETUP:
Date & Time:
- Set Date & Time
- Date format
- Time format
Display:
- Brightness
- Colour
- Map colour
Units:
- Temperature
System:
- Factory reset
- Software version
- Automatic scrolling
Click button Setup and 1+2+3:
Description of the unit
GPS coverage
Demo mode
https://drive.google.com/open?id=0B9c7L ... kI3ekFEMUk
x 6959
ok, give me a minute to go check on my car.
x 6959
Well it seems you are missing a menu option - the first menu before 'Date & Time' should be 'System Language'. What is your car VIN? - I need to see exactly what you have.
x 6959
Sometimes the system needs a reset after a firmware update. If you are willing to loose any music or other saved addresses in the system, this may be what you need to do. From SETUP, go to SYSTEM and then FACTORY RESET. Try this.
szymon189
Reset already I did.VIN sent in private message.
