- x 3296
Re: I am an Activa owner...a V6 and I am an addict
On the 'Activa' moulds you should add (in small print) "Cubed Tumbleweed"!
- x 1996
- x 1996
A lighting alignment rig using a spare slam panel.
As I know MY lights are perfectly aligned then switching from them to the new lamp units should get me 95% correct to marks on the garage door put there using my existing OEM lamp units.
- x 1996
Made a new (high) work bench from an old gate post (cut in half), some nice thick ply as a work surface and positioned next to wood stove to keep nice and warm.
- x 8400
I like it Alasdair
It looks like it'll take plenty of weight....
- x 1996
more than I could lift up onto it Jim
- x 1996
An experiment with dials.....
Day view-----------------------------------Night illuminated (grey looks black in the photo)
- x 1996
Originals are all green...
- Attachments
- x 8400
How did you achieve that Alasdair, knowing how the green tint is achieved?
Looks good through... Might it open the door to other colours too?
- x 1996
I will show you when you are down next
And yes, colour change is possible and there is no need to remove the needle, I was thinking blue for the numbers
furriegurrie
- x 40
I'd "mirror" it. Maken the figures and the bigger dash green and the smaller in between ones white. And the 70 red....
- x 8400
Stickyfinger wrote:I will show you when you are down next
Excellent, it's only a couple of weeks away according to my calendar
Looking forward to seeing you and visiting a different parkrun...
- x 1996
I had not thought about that......ummmmmfurriegurrie wrote:I'd "mirror" it. Maken the figures and the bigger dash green and the smaller in between ones white. And the 70 red....
- x 3296
I wonder if it might be possible, when the RPM hit the red line, to make the RPM gauge colour switch from green to red?
- x 1996
Not with this method.........colours will be set as this is just working on the dial.
