Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 206!!
ekjdm14
- x 263
Re: Black Xantia NA Diesel auto... Camshaft? No, conrod failure... Le moteur est mort...
I hold vainly onto that hope, Xantia V6... And I agree Jim, I think the piston crown hit the valve, thus snapping the cam & causing the engine to fail.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
OnlineCitroJim
- x 8412
xantia_v6 wrote:I have seen an (old) ford engine that looked like that, and the only bottom end damage was a broken piston with a detached crown. The rest of the piston and rings were still happily traversing up and down the bore.
Now given the construction of diesel pistons, there's a chance that may have happened here... I'm not sure which one it is but I believe one or more of the XUD family may have steel piston crowns on aluminium skirts...
In such a piston there is a good opportunity for such a failure to happen.
ekjdm14
- x 263
I do hope so Jim... Just a quick addition/correction. In my tiredness I stated emphatically that it was the inlet valves that had hit the pistons but now I've rested a while and look again it's quite obviously the EXHAUST valves that have clashed with the pistons. And looking at the valves in the head, they do seem a little bit clean even for running on veg...
So, as seller noted, cam timing probably has slipped initially, pistons mated with exhaust valves, very shortly after this the piston or rod on #1 failed also, the piston flew up and snapped the camshaft & the engine stopped...
Got to take the kids out so no "playtime" that I can forsee today, but when time allows I will be ascertaining exactly what has broken downstairs and posting back. I'll try and have a look what construction the pistons are too, be nice if it is that simple.
ekjdm14
- x 263
Oh, this still leaves me with a question... If (as?) none of the actual inlet valves have hit pistons, why is one lifter sat lower than the rest? (not lost a shim)
OnlineCitroJim
- x 8412
I'll ponder that next time I go out for a runekjdm14 wrote:Oh, this still leaves me with a question... If (as?) none of the actual inlet valves have hit pistons, why is one lifter sat lower than the rest? (not lost a shim)
You may need to remove the valve and bucket to answer that question...
ekjdm14
- x 263
Yes that is hopefully possible this afternoon so will update later. Hope it's nothing too bad as I'm in two minds as to if the head may be serviceable with a new cam and caps. What are your thoughts on the bearing damage pictures? Thanks
OnlineCitroJim
- x 8412
That head, based on the bearing journals is verging on borderline. Can we see some higher definition pictures?
ekjdm14
- x 263
I'll try and get some and post them up, do we have any clearance figures for these? I was thinking if there was, I could cut the undamaged bearing off the wrecked camshaft and then plastigauge the clearances after cleaning up the damage...
Just got back from taking the kids trampolining & it's pretty grim outside so may not be today.
Assuming the valve/guide with strange clearance are OK, the rest of the head is in very nice condition as you'd expect for a sub 100k motor. With a bit of brake cleaner & a toothbrush most of it could pass for new internally, even the valve heads etc.
ekjdm14
- x 263
Just had a play with the original pics, they seem to have zoomed in alright but will try to get better if need be... My "gut feeling" is that it may just be salvageable, since the really nasty bits of the scoring don't extend the full width of the bearings.
The worst of them is the centre bearing, the far side hasn't suffered quite as badly.
would be nice to save it if possible...
OnlineCitroJim
- x 8412
I reckon they’ll do another turn with a bit of care. Main thing is they will not cause a serious reduction in oil pressure... The first is a bit marginal in that respect but it might be worth experimentally filling the pits and gouges with chemical metal...
Really it all depends if any damage has occurred to the valve seat or guide on no.4...
ekjdm14
- x 263
Valve spring off, and valve is firmly seized into the guide. Managed to move it with a hammer but I expect the guide will be toast if the valve has to be drifted out... Looking more and more like a replacement engine may be the best way forward...
OnlineCitroJim
- x 8412
Yes, given the valve/guide damage, definitely go for a replacement engine... Especially with potential bottom end damage.
An ideal opportunity to put a TD in there now
Arguably, a good TD may well be easier to obtain..
Still interested to see the bottom end
ekjdm14
- x 263
Oh yes I'll certainly be dropping the sump still. Not sure about going TD as the insurance looks likely to be ridiculous considering it'd be still basically a standard model. Anyone have any suggestions for sympathetic insurers, as a decent TD would likely be easier to find?
OnlineCitroJim
- x 8412
LV are a good one in my experience...
I've tried most of the insurers over the last few years, LV for one year only as they did the 'get em hooked' trick, low price to start and increased the premium by a huge percentage for the renewal.
Currently with Direct Line who have been unbeatable on price, cover and excess amounts, now into my third year.
