squealing brakes
Dedicated to owners of Citroen GS and GSA models.
sonoramicommando
x 5
Re: squealing brakes
Unread post by sonoramicommando »
Right - I've done everything I could but it's no better. Squeal is tolerable for the first few minutes of driving then turns nasty volume wise and squeals pretty much non stop as soon as the pedal is touched. And it develops two different pitches/frequencies...
I'm taking it to a shop....
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
Stonehopper
x 118
Unread post by Stonehopper »
Did you change the pads? Or clean the discs?
Make sure the shop knows how to bleed the rear brakes on the GS/A!
Derek
x 1484
Brakes on my 307 stopped squealing when I replaced the discs that looked like they had been at the bottom of the sea for a couple of months! No doubt this needs new discs (or, if there's enough thickness, a skim, as GS discs are probably not on the shelf anymore!)
sonoramicommando
x 5
the discs look pretty tidy - haven't measured the thickness, I don't think I could get a vernier in with the stone guard left in. sounds like it could get a bit more expensive...
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
Stonehopper
x 118
http://www.ebay.co.uk/itm/Brake-Discs-r ... xyVLNS80tf
Search for - "brake discs Citroen GSA"
Derek
sonoramicommando
x 5
The shop replaced the pads and it's quiet as a ninja (well, I could still hear a faint amount, coming downhill, guessing that may have something to do with even less braking force on the rear - but it's way more tolerable)
Apparently they were original pads (doesn't surprise me)
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
