Sticking horn
Eddie Nuff
- New User
- x 38
Sticking horn
The horn is stuck on on swmbo's C4GP so the airbag has to be removed from the steering wheel hub to get at the ring where the horn contacts are. When pressing the screwdriver into the hole underneath the airbag springs up a small amount but will not pull out, as though it's stuck on the mechanism that holds it onto the wheel.
Any ideas on how to release it completely as it's annoying that it's so near and yet so far from completion.
- x 1431
Re: Sticking horn
I'll have a look later, but this may well not be a fault at the wheel - don't forget these are multiplexed, so the switch sends a signal to the BSI (and / or) the underbonnet fuse box, and then in one of these locations, a relay actually powers up the horn. If you could get it on diagbox you should be able to see if the ECU thinks the button is pressed.
In fact I have a dim recollection that this has come up before....
- x 1431
Re: Sticking horn
It just says:
Insert a large flat screwdriver in the orifice " a".
Push on the pin ( 2)By means of a screwdriver.
Unclip the airbag ( 1).
Disconnect the airbag ( 1).
Remove the airbag (1).
Where a is at the bottom of the central hub. Perhaps you just need to push harder!
- x 1431
Re: Sticking horn
And the wiring diag shows it going via the BSI to the underbonnet fuse box, where the relay is located to actually power up the horn.
Eddie Nuff
- New User
- x 38
- x 1431
Re: Sticking horn
Don't think so, Lexia will hopefully be able to tell you whether it thinks the button is pressed or not. When does the noise come on? If it's all the time, then it suggests independent of the BSI, and fault with BSM. If it goes off when the BSI goes to sleep, then perhaps fault with BSI or COMS unit.
Edit: In this thread, Wheeler implies (on a berlingo at least!) the horn is not via the COMS unit. I'll have another study of the wiring diagram...
Eddie Nuff
- New User
- x 38
- x 1431
Re: Sticking horn
Duh, failed on the link: viewtopic.php?t=30650
Actually I can't remember, maybe the hornworks irrespective of the status of the BSI? I'll check. I'd be leaning towards a fault on the underbonnet fuse box.
- x 6955
Re: Sticking horn
Do we have your VIN for the C4GP? I've been looking at the wiring for a 2008 C4GP and the horn is linked to the bonnet anti theft pin and then to the interior protection. Fuse F8 on the BSI Fuse Box I think controls this - but can't be sure without your VIN.
Eddie Nuff
- New User
- x 38
Eddie Nuff
- New User
- x 38
- x 6955
Re: Sticking horn
I can't attach PDFs here, so I've emailed them to you.
I've put a guide together for the codes here:
https://www.frenchcarforum.co.uk/wiki/E ... ring_Codes
Eddie Nuff
- New User
- x 38
- x 6955
Re: Sticking horn
Aren't they always! Just thought that they may help you trace the connections from the horn to the relay and fuse in case there is anything obvious there.
- x 1431
Re: Sticking horn
I had another look - seems to me to be 'soft' operated via the BSI / BSM. My money is on a fault with the BSM. I have a got a spare which will probably fit, and I think is OK - I bought another chasing a handbrake fault that turned out to be the EGR valve!!
