Confessions of a Citroholic
x 695
Re: Confessions of a Citroholic
Unread post by Mandrake »
CitroJim wrote: 5. Now that's an excellent idea! Both mine are in early autumn which is ideal...
I've been lucky so far with both my UK based cars that their MOT's have been due July/August - perfect timing for getting work done in the summer to get them ready! =D>
Of course in New Zealand a warrant of fitness is due every 6 months for cars older than 3 years, but it least it wasn't snow and ice if I needed to do any work in the winter. :lol: Torrential rain and strong winds though sometimes!
x 8437
Never realised the WOF was 6-monthly in NZ Simon...
A good idea methinks and something we ought to think about here rather than the proposed two-yearly MOT. A lot can happen to a car in the course of a year... Too much in the case of a non-caring owner...
Is the WOF simpler given its frequency?
x 695
No it's exactly the same as an MOT in scope. Yearly for new cars then 6 monthly for cars over 3 years old. At least it still was in 2009 which is when I last owned a car there!
It used to annoy me that it was so often but on the other hand when I came here yearly for an old car seems like a lot could go wrong in that time!
x 1498
2 yearly is an EU thing - HMG has resisted so far, and given the mammoth other things to sort out in the next couple of years, unlikely to be on the agenda!
On the 307 front, MOT site is reporting a pass :) Just advisories on the front wishbone bushes - first noted at 68k, now on 124k! TBH they don't look all that great, they are sort of delaminating from the arm, so I think replacement is probably on the cards later in the year. It's a bit of PITA though, as the bolts have puny TORX fittings on the top, so my guess is they will need to be cut off. The front one is also right under the driveshaft - I think the official procedure is to remove the shaft, but I'd have thought there would be enough room to get it out and in with the hub / shaft pushed right forward. There's also not enough downwards play to get the BJ taper out of the arm, so you have to unbolt the hub from the strut to lift it out of the arm. All good fun.... :roll:
x 8437
That almost sounds like 407 wishbones Richard... From experience it's painful and you end up wondering why on earth they were ever designed like that...
Hope the 307 ones are a bit easier ;)
x 1498
Changed over all the locking wheel bolts on both cars finally. Been meaning to do it for ages, but never got around to it - then when I was doing the brakes on the 307 last weekend, one of them slipped on doing up, so I decided time was time. I couldn't shift the one that slipped with a breaker bar, but there was just enough to get purchase on it using Mandrake's impact driver (which has been resting in my garage since the failed bottom ball joint episode). Thanks, Simon!!
x 1498
On the NS might as well remove the hub and shaft - it's going to fall out the gearbox anyway!
x 1498
Seemingly I don't have enough tools...! Went to fit the towel rail in the new bathroom, but the hex in the pipe connectors was bigger than my 10mm allen key, but smaller than my radiator key (of which I have 2), and I had nothing else of the right hex size, D'oh! Eventually found a file that was the right width to go in across a couple of the points and allowed me to tighten it up. No such thing as a 5 minute job.....!
lexi
x 133
Unread post by lexi »
You have NEVER got enough tools! :-D
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8437
lexi wrote:You have NEVER got enough tools! :-D
Yes, very true...
x 1498
'Cos I'm a bit of numbers saddo.... 25 years today since I passed my driving test! Where did that go???? 8 cars (me) 4 cars (her), close on 1/2 million miles, 2 clutches, gawd knows how many oil / filter / air filter / fuel filter changes, 2 prangs (both in the first 6 months of driving).
The next 25 years? Who knows!!!
x 8437
Happy 25th Anniversary Richard!
40 years for me this year passing the car test...
daviemck2006
x 485
Unread post by daviemck2006 »
37 years for me. And i have had 8 cars in a year! [emoji23]
Sent from my SM-T585 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 695
RichardW wrote:'Cos I'm a bit of numbers saddo.... 25 years today since I passed my driving test! Where did that go???? 8 cars (me) 4 cars (her), close on 1/2 million miles, 2 clutches, gawd knows how many oil / filter / air filter / fuel filter changes, 2 prangs (both in the first 6 months of driving).
Sat my driving test on December 12th 1990 on my 15th birthday so a bit over 26 years driving for me, sorry Richard. :lol: :twisted:
Two accidents in the first couple of years, both in my GS - one my fault, fishtailing into a ditch on a metal road in the country, the other not my fault, head on collision with someone who pulled out in front of me into the middle of a country road and stopped dead like a deer in headlights! #-o No accidents since then.
I've also owned 8 cars, roughly in this order (some of them overlapped each other and I can't remember exactly when I bought and disposed of some of them!)
1977 Citroen GSpecial 1129
1980 Subaru 1600
1984 Daihatsu Charrade Turbo
1977 Citroen CX 2400
1988 Honda Accord 2.0
1997 Citroen Xantia 2.0i
1998 Citroen Xantia V6
1997 Citroen Xantia V6
5 of the 8 are Citroen's so I think that puts me in good standing. (For the insane asylum :rofl2: )
8 Petrols, no Diesels. One Turbo. 5 manuals and 3 automatics!
Clutches - 0 (!) Radiators 1. Timing belts changed 2, timing belts snapped 0. Cars with timing chains instead of belts 2. Cars eaten by the rust monster 4.
Miles ? I haven't a clue, but unlikely to be anywhere near as high as yours! :mrgreen:
mickeymoon
Unread post by mickeymoon »
Passed my bike test in 1994 and car test in 1996.
Have owned 10 motorcycles and 146 cars.
