C5 serious suspension fault
Harlequin
x 24
Re: C5 serious suspension fault
Unread post by Harlequin »
when its set to on the floor low - should I be able to see any LDS in the tank filter?
x 6957
The car should be on the lowest setting and left for a few minutes to ensure as much of the system is depressurised as possible, then check that the LDS levels should be between the A and B marks:
LDS Fluid Levels
LDS Fluid Levels
Harlequin
x 24
hmmm it doesn't even cover the bottom of the basket
would too low lds throw up and error?
x 6957
No errors for low fluid levels, but you may get a general suspension fault if it becomes too low.
Harlequin
x 24
such as a serious suspension fault with errors from both height correctors? ECP have some for £8 this weekend for 1 litre
the bottom of the basket has a thin layer now
x 6957
I can't tell what C5 you have Simon from your profile. On the X7 there is a joint power steering / suspension fluid level warning, but can't remember it this is also on the Mark II. I'll see if I can find out. The fact that your error went awa y when you disconnected and reattached the ECU plug suggests that your car might benefit from a BSI reset. If you are going to do this, leave the battery terminal off for a good 10 mins before reconnecting it and following the rest of the procedure. This will help to clear down the ECUs properly.
Harlequin
x 24
Its an 02 reg (RPO 9250) mk 1 C5 2.2 HDi estate
and it took just over 500ml of LDS - went in green , certainly not green now after some citerobics!
x 6957
GREEN???? I hope not! It should be an orangey colour. Please don't say you have put LHM in instead of LDS?
Harlequin
x 24
nope? bottle has green liquid and is citroen LDS compatible?
x 6957
What is the make and what is the specification? Do you have a picture?
Harlequin
x 24
rated to PSA S712710
http://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_871
bottle says citroen LDS on the back!
Harlequin
x 24
given what I could see was / is black - I think a full system change might be needed and soon (odds on it hasn't been done! )
came belt done 7/7/09 in the service book though, so change soon as well?
x 6957
Personally I would only use the recommended fluid. In this case the Total Fluide DA which has replaced LDS. There are 2 litres here for £17.99, the same price per litre as that other stuff!
https://www.amazon.co.uk/Total-Fluide-D ... 1RMDW38M9H
x 1940
Just the name of the product - MT75 - would worry me as it sort of implies that it's SAE 75. I would dearly love to look at the back of the bottle to see if there's any more technical information there. The lack of a technical PDF or specification page also worries me.
x 6957
I've looked at the picture and there is nothing there apart from saying it meets the PSA spec. I still wouldn't use it due to the lack of information. I've heard it is made by Shell and is also recommended by the RAC shop, but I wouldn't necessarily say that means anything either as they are probably on kick backs! Can't seem to find the specs, so a no go for me.
