Navidrive 3D
elma
- x 287
Re: Navidrive 3D
In full holographic 3d I hope
- x 1942
Re: Navidrive 3D
Ah, then that wouldn't work for me as I get my breakdown service as part of my monthly fee for my current account.GiveMeABreak wrote:Basically, if you have Citroen Assist - then they will do all the necessaries for you. - That's the Chevrons Button. The Emergency SOS button is for emergencies depending on country - either 112 or your own emergency Country's emergency number. It should already be configured in the head unit a new.
So, if I did have a SIM in the car phone (not planning that ATM) I would have to do exactly as I said and put the breakdown number into the SIM.
- x 6957
Re: Navidrive 3D
Basically I just have all the key numbers on my Bluetooth phone - I rarely switch to the internal phone as I don't need to - leaving that for emergencies or an accident, then the car will do it's stuff. I suppose if you didn't have a bluetooth phone, then you would just bung all the numbers in the internal directory or the SIM card itself. The internal Directory is better of course because the voice commands work with the address book.
hoggers
- x 11
Re: Navidrive 3D
This plug that I've just found wouldn't have anything to do with the gps would it?
If not, any ideas what it's for?
hoggers
- x 11
Re: Navidrive 3D
Ignore me. It's the footwell light [emoji85]hoggers wrote:This plug that I've just found wouldn't have anything to do with the gps would it?
Sent from my iPhone using Tapatalk
Reason: Removed picture for space
- x 6957
Re: Navidrive 3D
Footwell light! - well somebody has been doing something in the back there for sure.
hoggers
- x 11
Re: Navidrive 3D
I suspect it was when the garage fitted the pollen filter on Wednesday - they just forgot to refit itGiveMeABreak wrote:Footwell light! - well somebody has been doing something in the back there for sure.
KP
- x 27
Re: Navidrive 3D
You don't even need to fit a stick on gps antenna. Just get one from a scrap car and then fit it behind the screen as there is enough space for one and the cabling. I've done it a few times with double sided tape to stick it all down and have the antenna facing the correct way as well.
It's also good for when retro fitting to vehicles without nav
MiKiller
Re: Navidrive 3D
Hello, i have same problem on my Citroen c5 2010, no visible satelits and poor localization, every repairer wher i go said to me that it is posible to be problem with unit.
Sorry for my bad English xD
