Navidrive 3D
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
hoggers
x 11
Re: Navidrive 3D
Unread post by hoggers »
GiveMeABreak wrote:Last of the big spenders! :rofl2:
And.. how big was that image.. :-D
I know how you like Large pics! [emoji23]
Sent from my iPhone using Tapatalk
x 6945
Re: Navidrive 3D
Ben - when you do go and give it a try - check if the message comes back up and if so, check if the light is flashing on the SOS button. If it is - then the recommended action from Citroen is to advise the dealer! That is according to a Picasso manual that said the same message (without the not inserted part). I know these cars like simple SIM cards - so it ispossible that it might not like the carrier or the SIM card type. I've go a Vodafone SIM in mine and no worries. You could always try a few to get one that it is happy with.
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:Ben - when you do go and give it a try - check if the message comes back up and if so, check if the light is flashing on the SOS button. If it is - then the recommended action from Citroen is to advise the dealer! That is according to a Picasso manual that said the same message (without the not inserted part). I know these cars like simple SIM cards - so it ispossible that it might not like the carrier or the SIM card type. I've go a Vodafone SIM in mine and no worries. You could always try a few to get one that it is happy with.
Just inserted the sim with the engine off and same message. Will buy a couple of different sims tomorrow [emoji849]
x 1940
Re: Navidrive 3D
Can't you try a known working SIM from a mobile phone first?
hoggers
x 11
Re: Navidrive 3D
Paul-R wrote:Can't you try a known working SIM from a mobile phone first?
My network is is three. My Mrs is EE but she's out at the moment... if she's back at a reasonable time then I may see if I can nab her sim!
hoggers
x 11
Re: Navidrive 3D
Success! Tried the wife's EE and ended up calling a very lovely lady in emergency breakdown call centre [emoji23]
x 6945
Re: Navidrive 3D
I guess the Mrs will be moving to the 3 network in that case!
elma
x 284
Re: Navidrive 3D
Unread post by elma »
Oops, but at least you know it works.
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:I guess the Mrs will be moving to the 3 network in that case!
[emoji23]
hoggers
x 11
Re: Navidrive 3D
elma wrote:Oops, but at least you know it works.
[emoji1303]
x 1940
Re: Navidrive 3D
Does the screen show the signal level of the phone? And is it fairly decent?
At least it's showing that the cable to the aerial unit is OK. I don't know whether the aerial unit has an amplifier for the phone frequencies - I actually rather doubt it - and if there isn't one then it can't help with knowing whether the DC power supply to the aerial is OK. But the chances are that it probably is. Which is a long way of saying that the sat nav problem is probably the lead or the radio itself.
hoggers
x 11
Re: Navidrive 3D
Paul-R wrote:Does the screen show the signal level of the phone? And is it fairly decent?
Didn't look at the signal level to be honest, it was too cold! Will check tomorrow when I get a EE SIM
x 1940
Re: Navidrive 3D
As EE and 3 use different networks and hence masts, see what the signal is for both.
hoggers
x 11
Re: Navidrive 3D
Paul-R wrote:As EE and 3 use different networks and hence masts, see what the signal is for both.
Already tried three and it didn't work. tried EE and it works
hoggers
x 11
Re: Navidrive 3D
Bought a Pay As Yo Go EE SIM today and popped it in and all is working fine. When you call the breakdown people - how does it work exactly? I've got breakdown cover with my bank card so do they do all that or do I have to have some sort of plan with Citroen??
