Navidrive 3D
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
hoggers
x 11
Re: Navidrive 3D
Unread post by hoggers »
Paul-R wrote:Hoggers, I don't suppose that you have a SIM card in your Radio or have tried a SIM card out in it? Knowing that it worked, or not, might help.
After searching high and low I found the SIM in the glove box - bought a sim for 99p as I thought that had something to do with the GPS [emoji23] further reading and I found out it was for the internal phone [emoji849]
Sent from my iPhone using Tapatalk
x 6948
Re: Navidrive 3D
The Internal phone needs a SIM for the Emergency system to work but can also be set as the default phone if preferred over a Bluetooth phone.
x 1945
Re: Navidrive 3D
hoggers wrote:After searching high and low I found the SIM in the glove box - bought a sim for 99p as I thought that had something to do with the GPS further reading and I found out it was for the internal phone
That's right but they work through the same aerial. They probably have separate feeds between the radio and the aerial unit but it would be interesting to know.
I've not done it myself, I use Bluetooth to connect, but you could try using your ordinary mobile phone's SIM. Assuming you have a mobile phone of course.
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:The Internal phone needs a SIM for the Emergency system to work but can also be set as the default phone if preferred over a Bluetooth phone.
Is there anything you don't know?!
I prefer the Bluetooth to be honest, although I wouldn't mind the emergency system just in case. I have a random SIM which doesn't have the same number as what I have but I guess that doesn't matter?
x 6948
Re: Navidrive 3D
No doesn't matter, as long as there is some credit on there.
There's a voice command training programme on there too when you get the other issue solved!
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:No doesn't matter, as long as there is some credit on there.
Ah ok, so I just need to put some credit on the SIM card for it to work the emergency thing.
Did the C5 only come with a beige headlining?
x 6948
Re: Navidrive 3D
Yes that's all you need. Just don't press the SOS button unless an emergency as it goes through to emergency services!
I think beige was the only colour AFAIK.
x 6948
Re: Navidrive 3D
There is a stolen vehicle tracker unit behind the dash on some models. It uses the built in phone to communicate I think.
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:There is a stolen vehicle tracker unit behind the dash on some models. It uses the built in phone to communicate I think.
I turned off locations on my phone and GPS tracking stopped! I should have known better!
jgra1
(Donor 2021)
x 36
Re: Navidrive 3D
Unread post by jgra1 »
I see why you asked about rooflining in my other post now hoggars! sorry I can't be of more help with removing it.. re airbags.. at least disconnect battery and leave car for a while..
follow the battery reconnection procedure I would (read it before disconnecting)
john
hoggers
x 11
Re: Navidrive 3D
jgra1 wrote:I see why you asked about rooflining in my other post now hoggars! sorry I can't be of more help with removing it.. re airbags.. at least disconnect battery and leave car for a while..
john
Thank you
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:Yes that's all you need. Just don't press the SOS button unless an emergency as it goes through to emergency services!
One brand new SIM card with £5 credit
Here's what happens
https://vimeo.com/200399975
x 6948
Re: Navidrive 3D
Last of the big spenders! :rofl2:
And.. how big was that image.. :-D
x 6948
Re: Navidrive 3D
Make sure you insert the card with the engine and ignition off first, as it can throw a wobbly.
hoggers
x 11
Re: Navidrive 3D
GiveMeABreak wrote:Make sure you insert the card with the engine and ignition off first, as it can throw a wobbly.
Il brave the cold and try it in a bit but don't hold out much hope with the luck I'm having with this car!
