Navidrive 3D
- x 6945
Re: Navidrive 3D
Ah, but it's not just a Sat Nav though is it....
https://www.frenchcarforum.co.uk/forum/ ... nd#p484102
- x 1939
Re: Navidrive 3D
Meh, I can live without that.
hoggers
- x 11
Re: Navidrive 3D
Done the update I think - took about 15min
It still says 2009/10 version is that right?
Sent from my iPhone using Tapatalk
hoggers
- x 11
Re: Navidrive 3D
More importantly the satellites still read 0
- x 1939
Re: Navidrive 3D
2009/2010 is the edition of the map data not the software.
That costs money to update. I've seen groups of people coming together to form a collective to purchase one copy a new edition of map data and then share it out.
- x 6945
Re: Navidrive 3D
Ben - if that's the new screen shot, then no - it has not updated! (top picture). It is still showing the same firmware version as before. As Paul says, the maps are separately purchased (just google Citroen Navigation) and yes that is the early map - the latest is 2016 second edition that has just come out.
Just noticed you've posted the old screenshot - the time is the same as your earlier post!
Ensure the car is running first and on the navigation screen, then insert the USB and wait - if nothing happens then either the files are not on there or the format is wrong. Did you 'unzip' the files onto the USB key? You should just have the following on the USB - one folder and one file, nothing else.
- x 6945
Re: Navidrive 3D
I did say that this probably won't solve the satellite issue - but there is no harm in having the latest system software installed on it. I still think your best bet is an aerial trace to check for damage and a diagnostic, which won't cost you much if anything if using a Forum member for help.
hoggers
- x 11
Re: Navidrive 3D
Yeah my bad. Here is the updated version.GiveMeABreak wrote:Ben - if that's the new screen shot, then no - it has not updated! (top picture). It is still showing the same firmware version as before. As Paul says, the maps are separately purchased (just google Citroen Navigation) and yes that is the early map - the latest is 2016 second edition that has just come out.
I've just pulled out the head unit and all the wires are firmly in the back so it's looks at though i need to get the headlining down, which I'm not entirely sure I have the nerve or skill set to do [emoji51]
The car is going in for a full service next Wednesday and they have a SnapOn diagnostics - will this be able to detect any errors in relation to the aerial?
- x 3296
Re: Navidrive 3D
I do know that my Lexia clone has detected a problem with the aerial base unit on my Mk1 C5.
- x 1939
Re: Navidrive 3D
That's a well known phantom error message on the Mk1 (and Mk2??). I haven't heard anyone complain about a phantom message on the X7 so I hope it doesn't exist.
- x 1939
Re: Navidrive 3D
Hoggers, looks to me like the SW has updated.
Looks like it's trace the aerial lead time!
hoggers
- x 11
Re: Navidrive 3D
[emoji85]Paul-R wrote:Hoggers, looks to me like the SW has updated.
Anyone you know that lives in the South that can assist?! In really don't want to be messing about around the airbags etc
- x 3296
Re: Navidrive 3D
Some of the forum members do have Lexia clones, and are willing to help out. Here is the link;
https://www.frenchcarforum.co.uk/forum/ ... 19&t=56452
- x 6945
Re: Navidrive 3D
We covered this a few posts ago James on page 2!
Ben has the list.
Ben - I think you already identified a member in Dorset near to you - send him a private message as back up, as it can take some members a while to respond. I doubt that your snap on guy's tool will be able to do everything that a Lexia can - but you can ask them to trace it back and check it for you.
In the interim - try a unit reset - with system on and engine running, hold down the EJECT button to the left of the DVD slot and the system will reset. Again no guarantee as I believe this is a signal from aerial issue.
- x 1939
Re: Navidrive 3D
Hoggers, I don't suppose that you have a SIM card in your Radio or have tried a SIM card out in it? Knowing that it worked, or not, might help.
