Cant find the problem need help! £2k down already
falling-out-with-my-car
x 25
Re: Cant find the problem need help! £2k down already
There are not that many things to stop a diesel from starting the stop solalanoid on the pump sounds like a good candidate for testing on this one if fuel is not getting through then no matter how much cranking you do it won't start. Sounds like that trapped lead could still be damaged proberbly the tdc sensor lead. Has he got a lexia to fault find with?
ekjdm14
x 256
Unread post by ekjdm14 »
HDi won't have a stop solenoid, the cut-off is done through the injectors not opening. To be honest I'd be sketchy on my faith in the mechanic if he "thinks" the immobiliser is stuck on... Lexia would tell him if that was the case or not... I can't recall if the car is being hooked up and basics like fuel pressure/cam-crank sync etc being checked but if not then it should be... Throwing ECUs at it isn't going to make a wiring or mechanical fault go away, and if a second ECU is indeed dead it would point me to wiring trouble still & I'd be inclined to double/triple check all potential areas for shorts before maybe frying another brain [-X
EDIT- re-read the post and can't find any reference to it being on a Lexia, it NEEDS to be diagnosed through this as a starting point rather than your man's throw-expensive-parts-at-it routine that's cost you 2k so far... it could be as simple as an air lock in the fuel causing low rail pressure... To be honest, if he's not had it on a Lexia then I would want to take it to somewhere else that understands modern common-rail stuff :?
'96 ZX SX 1.9TD, White, 88k
'98 Ford Fiesta 1.3i 72k
x 25
blimey I have a lot to learn hdi's now I own one.
Thanks ekjdm14
ekjdm14
x 256
Same here, still an awful lot for me to learn but this forum has been a great source of info as usual. It's this that makes me wonder about rail pressure, since I read a similar thread on a non-starting HDi where I learned that the injectors won't even begin opening until the ECU "sees" a certain fuel pressure (somewhere over 150 BAR, these things really are HIGH pressure!!!) and if the pressure is below this no amount of cranking over will purge the air out like with mechanical injection. Actually, if memory serves that was also a 1.4HDi and also had a problem where a wire got damaged. I'll try and find it and add a link in case it's of any help to welshie... Certainly won't get far without Lexia sessions though.
EDIT- here's the link to that thread, it was indeed a 1.4HDi and it was fixed quite cheaply in the end. Click me! I would reiterate though that Lexia is a must, theres very little chance to sort these without it & unlikely the car in that thread would be running without having been hooked up...
Welshie
Unread post by Welshie »
Just been and spoke to the mechanic. He is using lexia. He has 3 versions of it and none of them are communicating with the bsi. When he plugs it in it only shows abs and ecu. No option for clocks/radio/key coding or anything else and the immobiliser has tripped and he can't access the bsi to program it properly. He believe's 2 wires are broke. He is going to try bypass them to see if it's the wiring or bsi that's not working. He has done another bsi reset incase this was the problem but no change.
x 6954
Welshie wrote:Hello. Just spoke to the garage and my van is dead! He can't get it to fire up. It turns over but won't start. He has had it back for 3 weeks and can't find what's wrong. He has checked everything that has been said and done a bsi reset 3 times. He's now going to gt a 3rd ecu and try this instead as he thinks the immobiliser has come on and won't go off....looks like it going down the scrappy!!
I note in your earlier post above you said the mech. was going to get a third party ECU. What specific ECU is he talking about? If it's an engine ECU or BSI he can't just replace them - they will need to be a matched set compatible with this car, along with the keys. In your original post, you mentioned that the ECU was fried and he had repaired / failed and then replaced it. It would really help further if we knew what ECUs have been replaced as there can be over 20 ECUs in these cars!
If the engine ECU and or BSI has been replaced and you have a matching transponder chip key set, are these the correct versions for this car? There were various levels of BSI depending on trim levels. At one stage there were 3 levels of BSI, but on newer cars about 2009 on they upgraded and replaced the BSIs with newer types which are NOT backward compatible. I.E. If you had a newer type of BSI as originally fitted at factory, and have replaced it with a second hand unit of the old type - it will downgrade the vehicle and cause problems (even though the connector plugs are identical).
This issue of engine turning over without starting can also be associated with an engine-locked vehicle.
x 1987
Unread post by Stickyfinger »
Standard garage ~ modern matched electrics + MONEY spent = Rare success
so it seems
x 6954
Welshie - can you post up or PM your VIN please.
x 6954
Another possible issue you will have - I see this is in relation to a Citroen NEMO - in order to properly diagnose these cars, your mechanic will need an S1279 Add-on module for the Lexia. These cars come under the 'commercial' designation and need the add on unit to work properly with the Lexia:
This is the add-on module for some of the vehicles that were jointly developed with FIAT and some of the commercial vans such as the Peugeot Bipper, Peugeot Boxer III, Peugeot Boxer III minibus, Citroen Nemo, Citroen Jumper III, Citroen Jumper III minibus etc. and is called the S.1279
1279 Add-On Module for Lexia 3 (Bipper, Jumper, Nemo etc.)
Welshie
He did replace the ecu with the same one. Matching serial numbers. He got a new engine ecu clocks and key. He got the whole set of a doner van 09 plate mine is a 59 plate. He did say it's near impossible to find a 2nd one tho. He had it running and I had it back for a few days but with no power. Went back to the garage over Christmas. Mech broke up for Christmas 3 days later. Came back off holiday and now it won't start. He thinks this is because the immobiliser has tripped. The mech is no longer charging me because he is determined to fix it. He almost bought me a new van to use whilst he stripped my van apart and re-wired it....that would of been a bonus!! He is giving it his best. Can't post vin number as I'm 27 miles away from the garage working. Soon as I get the chance I will pop over and get it. It might be a different engine number though as it had an engine replacement 2 years ago done by a citroen main dealer. And I will check soon as possible if he has this attachment for the lexia. I'm sure he does as he said he needed to buy some new equipment to try diagnose the connection issued it's having
x 1987
the Vin is on your V5 and you MoT cert fyi
x 6954
Welshie - I've sent you an email with some technical docs on the Engine ECU and BSI for the NEMO in case they are any help to you or your mech. Some contain programming info and initialisation procedures that may or may not help. This is going to be a tricky one given that it has already had some ECUs transplanted - in nailing the problem down specifically. Assuming he also replaced the BSI (which he would have to have done when replacing the engine ECU), did he record down all the settings from the original BSI before taking it out? This is the general procedure to ensure that all the correct components and options are able to be manually reprogrammed in on the new one - as I assume he does not have access to main dealer server ECU downloads.
Although the BSIs may have the same identification - it doesn't mean they are configured for the same engines, components and trim options - hence the need to record or screen shot previous settings in lieu of an ECU download. Plus of course there is the software versions applied to the BSI - these too could be different from the donor car and your vehicle.
x 25
blimey Marc you certainly know your stuff.........
x 1987
I think Marc's avatar is quite accurate :)
x 1751
Stickyfinger wrote:I think Marc's avatar is quite accurate :)
The avatar does look uncannily like Alan Johnson, ex-Home Secretary :|
