- x 1746
Re: Simon's new Xantia V6 blog
Interesting the mention of the sealing fluid "going milky". Remember that old "Barrs Leaks" fluid did the same: about 150ml thick and brown in the tin, which went milky on contact with warm water. Many cars from post-war times onwards ran with it.
- x 1498
The Forte stuff is a milky blue colour to start with. Very odd stuff!
Matrix reference info: https://www.frenchcarforum.co.uk/forum/ ... 11&t=29981
Despite doing over 200k across 3 Xantias it is a job I have thus far avoided....!
- x 695
This kind of assistance ?CitroJim wrote: It's certainly a job that needs assistance.
lexi
- x 133
The miliky blue stuff is probably a latex type fluid with " liquid glass" in it and maybe a binder. I made the glass last year from silica cat litter and sodium hydroxide. I then put it in a mix of perlite and high alumina cement, with sand. Refractory for log burners.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 695
Well that's the Forte arrived already, so if its not raining I'll see if I can get it in there tonight so that it has the rest of the weeks commute to do its thing...
Is it best to add it when the coolant is cold or hot ? And should I go for a drive to heat things up and mix it after adding it rather than leaving it for the following morning ?
One more question - assuming it does block the leak and lasts a long time (like Richard's example
) when the coolant is next changed, would more Forte need to be added to prevent the "repair" from being flushed out ?
Driving all the way down south and paying someone else to do a very labour intensive job is just not going to fly with the other half.
Pushed for time is mainly about getting it back on the road again for the Monday commute - driving all that way with a coolant leak worries me more than my own ability to do the job...
Normally I like to do as much as I can myself but after reading through that thread it really does look like a two person job - or at least a two contortionist job!
Looks like a bit of preparation work is in order too including getting the correct o-rings from Citroen, checking I have some of the necessary specialised tools including some way to get the scuttle off and back on... my scuttle is already badly cracked in several places - I strongly suspect it's been off before!
If I had a spare car for the daily commute and the luxury of taking my time I wouldn't sweat it at all, I'd just pick away at it until done but unfortunately I now rely on the car for the daily commute.
Fingers crossed that the Forte works as well as it did for you! I'd feel guilty if it worked too well and I never replaced the matrix though...
I've discovered I have a spare unopened 5L bottle of coolant from the last coolant change, so I think I'll drain 1-2 litres out via the radiator drain tap (which should still be working as I only changed the radiator a few months ago!) and then add the Forte then top up with coolant no more than half way as you say, so none gets wasted.CitroJim wrote: Yes, if need be, drain out a bit of coolant from the expansion tank. Or rather than draining, just use a turkey baster or similar to suck some out...
Then add the Forte but ensure there is enough coolant removed to ensure that none of it can be lost through the overflow when the system is up to temperature and pressure... You don't want the level anywhere above the mid-point of the tank (i.e the top of the internal framework) or you will loose some out of the overflow.
It will soon circulate as the coolant in the expansion tank is by no means static or stagnant... There's a decent flow going on...
Thanks for the suggestion David but I think it's a non-starter on many fronts.DHallworth wrote: If you're pushed for time and need it done quickly, have a weekend away and book it inOne way of guaranteeing it's done right and back together quickly.
You might live to regret the offer.RichardW wrote:I put Forte in my HDi as a temporary measure till I could get to the matrix. It was still there when it went to the scrap yard about 75k later; and still sealing the matrix![]()
Let me know when you want to do it, I'll come and laugh, er, no I mean help!!
I'm onto my third Xantia too and maybe about 50k miles all up and had avoided having to do a heater matrix until now but I suppose at 19 years old it's fair enough if it was the original!RichardW wrote:The Forte stuff is a milky blue colour to start with. Very odd stuff!
- x 1746
Probably ok to add to cold coolant (you could always dilute it with a bit of coolant before adding it), but a good idea to then take for a drive, to get it up to temp, stat open, and well circulated. And then it's bleeding time.
- x 1498
I would go for a drive to make sure it circulates rather than sitting at the bottom of the header tank. It took a week or two for the one on my HDi to dry up - but that had the worst leak (I Forted all 3 of mine!).
No problem with coming to help - or bring it to mine and we can get medieval on the ball joint at the same time
I added more Forte to mine when I changed the water pump - however, it always lost coolant after that (due to cooking the electric heater - and that was beyond Forte) and I never put any more Forte in - and the matrix never leaked.
- x 8437
Agree fully with both Chris and Richard on how to add the Forte Simon.... I've added it cold and then gone immediately for a decent run to get it well circulated...
As far as I know it doesn't separate out if left standing...
I howled at your 'two contortionist' comment Simon
Actually, yes it is!
- x 2006
Run the car with the rad covered (at the back) with card, run at 2k revs and with the cap off from the start, it will soon start to circulate as the thermostat will open quickly.
- x 1746
Yes, petrols do warm up rather quickly. All that waste heat!
I'm not used to that . . .
- x 695
Well the rain held off so I've put it in tonight.RichardW wrote:Simon
I then poured the Forte in (which still didn't make it visible in the bottom) and about half a litre of new coolant on top of that to bring it up half way in the expansion chamber. I then went for a couple of spirited drives up the M74 to get it nice and hot and circulate it.
For the last few days since I noticed the leak I've had a fresh sheet of kitchen roll each day up in the top right corner tucked under where it leaks - any leak shows up clearly as a wet patch spread out on the paper, the bigger the patch the more leakage. I've been seeing a double folded piece of paper become soaked half way across each day - not massive but quite a bit.
I was expecting it to take a few days as you suggest Richard but to my surprise after both test drives the new piece of paper was completely dry!
Does anyone know what the leak is likely to be ? Do they usually pinhole in the radiator core, or do they leak at a joint somewhere ?
I'm not that much of a glutton for punishment to attempt both a heater matrix and that really stubborn balljoint in the same weekend.No problem with coming to help - or bring it to mine and we can get medieval on the ball joint at the same time![]()
It does need doing though, whatever that rattle is is still getting worse. I now notice it when I accelerate on a tight right lock - if there is any loss of traction it rattles quite badly with the wheel torque.
CitroJim wrote: I howled at your 'two contortionist' comment SimonActually, yes it is!
I've done enough under dash jobs like heater blower relay modification to know how awkward it is to be under there upside down legs sprawled over the folded down front seat.
- x 8437
That's looking promising Simon
My experience suggests it's rarely the matrix itself that lets go but rather the O Rings on the joint between the matrix itself and (for want of a better word) the 'interface' to right angled elbow connector...
The ones I've looked at have gone very hard...
It's a brave person who juts replaces those O rings (not available as spares) and reassembles everything just to see if it's worked... I've never been that brave!
I have seen one holed and I believe it was a poor quality one that was just a little too big and the bottom 'U' tubes rubbed on the base of the heater box and thus holed after a while due to vibration and movement...
- x 1498
Lightweight!Mandrake wrote: I'm not that much of a glutton for punishment to attempt both a heater matrix and that really stubborn balljoint in the same weekend.![]()
Ah, you've missed out on the joy that is changing the clutch clip on a manual Xantia.....Mandrake wrote: I've done enough under dash jobs like heater blower relay modification to know how awkward it is to be under there upside down legs sprawled over the folded down front seat.
- x 8437
RichardW wrote: Ah, you've missed out on the joy that is changing the clutch clip on a manual Xantia.....
The clutch clip can be especially character building....
- x 695
Still no leakage after this mornings trip - I was not expecting it to work this quickly! Let's hope it holds up...CitroJim wrote:That's looking promising Simon![]()
Ok that's good to know.My experience suggests it's rarely the matrix itself that lets go but rather the O Rings on the joint between the matrix itself and (for want of a better word) the 'interface' to right angled elbow connector...
The reason I was curious is that if it was something like a pinhole in the aluminium due to corrosion then I would consider this to be a temporary fix at best, however if it is helping a hard o-ring to seal by sealing the gap between the o-ring and the surface the o-ring is supposed to seal against using something sticky it could very well last a long time...
I'm guessing that part of the formulation of the stuff targets bonding with rubber o-rings specifically.
