What do you know about SB pre-tensioners & joining wires.
elma
- x 284
Re: What do you know about SB pre-tensioners & joining wires.
Treat yourself to some leaded solder and it'll be fine. I thought I'd lost the knack of soldering for years but it turns out I'm still quite good at it so long as I use the leaded stuff.
- x 8444
Agreed...elma wrote:Personally I'm not a fan of those type of connections, a soldered joint would be my choice. Crimps are perfectly good in a static environment and have there uses, especially in panels and machines, but are not what I would choose over soldering here.
Crimps on the very thin wiring typically associated with air-bags and pre-tensioners can be very unreliable and difficult to make absolutely successfully. Much better soldered...
For true flexibility what better than cable like this.....
http://www.fscables.com/Power/Spiral+Ca ... e/list.htm
Just happens to come in a nice orange too!
elma
- x 284
Looks like a good option.
