Trying To Avoid 1.6HDI Turbo Failure
renagade
x 10
Re: Trying To Avoid 1.6HDI Turbo Failure
Unread post by renagade »
Ho bloody hell, I have just bought a 2011 1.6 e-hdi c5 with the egs6 gearbox and stop / start. The garage insisted they change the oil and filter before I took delivery of the car. Can you tell me what torque these bolts need to be please, I must get this sorted as on pension and have no extra cash to repair or change the car. [-X [-X
There are so many roads to travel but so little time, (Paul Cofield )
x 6948
Welcome to the X7 club!
What are you referring to? Torque for what bolts? I think I have your VIN already - so this is based on the DV6C Engine on your car:
Here are the Lubrication Component & Turbo Torques in case you mean these:
Lubrication:
Turbo:
x 1498
Presumably the injector clamp bolts - which as it is a DV6C you don't need to worry about! They swapped back to proper injector clamps with decent sized bolts, and the DV6C gives virtually no problems with leaky injectors or turbo failure.
x 6948
Useful to know FFR Richard.
renagade
x 10
You are a star mate, I thought that my car was one of those that had the turbo failure every other month. I still will do my oil changes every 6 k though that will take me over a couple of years to do, i don't drive much as you can guess.
renagade
x 10
is engine no JBEG3007564 a DV6C. On the plastic engine cover, it has hdi 16 does that mean 1.6 or 16 valve ?????
x 6948
That means 16 Valve on the engine cover, but in your case the DV6C is also 1.6L Engine.
renagade
x 10
So,,,,, Does my engine have 8 valves or 16 valves and going by the engine no. does it have the updated fixings for the injectors??????
x 6948
Ok, you can be forgiven for getting a little confused - not helped by that engine cover either. Mine is a 2.0 HDi 16 Valve. My engine cover says HDI 16 on it - so I assumed that was 16 valves - the fact that you have the same on yours is odd - unless they decided 'what the hell why bother with 2 covers - it'll do for both a 16 valve engine and a 1.6 engine with 8 valves'!
You have the DV6C engine, that as Richard refers to was changed in 2011 and reduced from a 16V DOHC to an 8V SOHC. Looking at your VIN the '9HR' denotes DV6 1.6 HDi - so look under the 9HR column below.
Regarding Valves - here is a piccy of your setup:
x 1498
An 8V engine should have a felt cover.., but looks quite different under the cover, see pics in this thread:
https://www.frenchcarforum.co.uk/forum/ ... 19&start=7
x 6948
Looking at the docs for Renegade's car shows this cover - which is almost the same as the Picasso one Richard, bar the 'e-HDI'
x 1498
Ah, only ever seen one in a Picasso with that felt cover.... learn something new every day. Anyway, the turbo outlet and DPF are a different shape on the DV6C so it should be ID able regardless of the cover.
x 6948
It seems there are always some 'crossover' issues when the models change engines - 'Oldboy' seems to have his share with his Picasso too!
Old-Guy
x 33
Re: Trying To Avooid 1.6HDI Turbo Failure
Unread post by Old-Guy »
wideboyno1 wrote:The Xantia never had the 1.6hdi so would not have suffered this issue.Bullet proof 2.0hdi was in every one i had.
However,when i purchased my '05' c5 mk2 it had this engine in.I never knew about any of the problems associated with it and when the seller made a big deal about it having a brand new turbo and associated paperwork i actually thought it was a good thing,especially the relatively low mileage at 68k.Needless to say,8 months-ish later although it wasn't the turbo that went there was bottom end engine damage which ended up me selling it on and losing a shed load of money.Only after buying it did i discover the problems with this engine when my inde looked at me in horror when i took it in.I'm convinced that the previous turbo failure and not very thorough replacement contributed to its demise.All the things you have mentioned will certainly help but non more so than very regular oil changes i suspect.
Put it this way i will never have that particular engine in any car again,especially a big car like a c5.
If we are talking about the 16V HDi (DV6TED4) 110 engine, the Citroen warranty fix was to replace turbo, modified oil feed pipe (larger dia?) and replacing the oil pump with an uprated one. As its a lot of work to change the oil pump, it wouldn't be surprising if sometimes (non-warranty of course) the pump wasn't changed or the bottom end inspected - not easy to tell without a bottom-end strip.
However, the 2011-on 8V (DV6C) 110, 112 or 115 (Citroen can't make up their mind what it's rated at) engine this does not appear to suffer the same problem.
With all these high-output (highly-stressed) engines, it's essential to drain as much old oil as possible: drain when really hot (cooling fans running), filter off first, leave to drip for 10 minutes; only then replace filter and fill with correct amount of the specified oil quality. NEVER use an oil that doesn't meet the Citroen spec.
Eddie Nuff
New User
x 32
Unread post by Eddie Nuff »
The 8v engine is what PSA should have produced first - but hey . . . The egs box on the other hand is just pure s**t!
