Davie's french attraction.
elma
x 284
Re: Davie's french attraction.
Unread post by elma »
I thought maybe it was a 4wd version.
x 8415
Fixed your signature for you Davie ;)
daviemck2006
x 485
Unread post by daviemck2006 »
Now I need to go log on via the Internet rather than the tapatalk app to see it [emoji49] [emoji37] [emoji12] [emoji13] [emoji23]
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8415
Looking at the forum through a web browser is the better way Davie... You see far more ;)
I just can't get on with CrapaTalk...
I've tried hard but no, it's not to my liking at all. A shame as the concept is basically sound, just poorly executed.
superloopy
x 19
Unread post by superloopy »
I use TT almost all of the time. Easy peasy to check across multiple forumae...
Sent from my LG-D855 using Tapatalk
Mike
x 8415
I'm just a one forum and Facebook sort of person myself Mike... No time for multiple forums...
Except the odd look at the vintage wireless forum...
mickeymoon
Unread post by mickeymoon »
The older version of tapatalk, when you've fiddled with it and worked out your preferences, is fine. They ruined it with the later version.
x 8415
The trouble with any version of Tapatalk I find, is you see only a little bit of any forum. You loose the big view. A bit like looking at a forum through a small movable slit..
A bit like watching TV through your letterbox whilst crouching in the porch.
I just can't work like that.
elma
x 284
If you really have to thats probably the best way to watch TV, keep a safe distance.
demag
x 102
Unread post by demag »
I do TT most of the time. I'm generally only on the PC after 7pm when the missus puts the soaps on. We have dinner and watch Pointless and the news then I make a swift exit!
Dave
superloopy
x 19
Re: RE: Re: Davie's french attraction.
demag wrote:I do TT most of the time. I'm generally only on the PC after 7pm when the missus puts the soaps on. We have dinner and watch Pointless and the news then I make a swift exit!
I to do TT most of the time. I'm generally only on the PC after 7pm when the missus puts the soaps on. We have dinner and watch Pointless and the news then I make a swift exit!
Unabridged copy with the exception of an additional 'to' ... that's my usage exactly [emoji6]
Mike
demag
x 102
Davie that's impressive mpg. What sort of speeds was that?
Dave
x 8415
At 7PM I'm well and truly 'off the air' and winding down in readiness for bed at around 8...
daviemck2006
x 485
demag wrote:Davie that's impressive mpg. What sort of speeds was that?
It was entirely on single carriageway rural roads at 55 ish mph
Sent from my SM-G361F using Tapatalk
Peugeot boxer 2016
In the family
daviemck2006
x 485
I know it's Spanish but here is a photo of the dash of the Leon
That's good mpg me thinks! The reason for the cheapness of the car is now clear to you, 181k covered. However, 2 owners, first one did 60k in 3 years and it was serviced at the supplying dealer when it should have been, every 20k. It then was serviced by a local Indy every 10k without fail with a timing belt at 80k and 160k. It drives like a lot less miles. I'm on a mpg check, 160 miles now, I'll do a brim to brim check and see how accurate the 63mpg is. That's the most economical car I have ever had. Even either of the 107's managed over 60mpg regularly
Peugeot boxer 2016
In the family
