Old Remote Key Fob into New Car?
x 6948
Re: Old Remote Key Fob into New Car?
I know Citroen will provide you with the code if you can prove ownership, so I'm sure Peugeot will should you wish John. But it will be interesting to see your results from the experiment!
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
thanks marc.. I will get that code .. but the locking unlocking is ever so slightly more pressing.. but before all of that the restoration needs an mot! :) wish me luck soon!
x 6948
Bonne Chance!
cancunia
Unread post by cancunia »
jgra, I think that what you're wanting to try is in part exactly what I was thinking about.
"as I have the basics in place I may try an old fob .. I cant quite see what harm it would do"
From what the ebay guidance linked in one of my earlier posts says, it's perhaps possible to get an old fob to lock / unlock. Keep us posted!
uncle buck
x 10
Unread post by uncle buck »
Some very interesting reading on the subject...
>> HERE <<
Cheers.
2001 Xsara II 1.4 LX
x 6948
Interesting, but I couldn't quite make it through 176 posts - still a hell of a faff and not for your average guy - but thanks for posting Unc. :)
cancunia
uncle buck wrote:Some very interesting reading on the subject...
>> HERE <<
Cheers.
Yeah, I was reading that thread too, it took up a fair bit of time to sift through!
uncle buck
x 10
So in a nutshell,
It is possible to use a 2nd hand remote key and get the remote part working, however, it's not easy and requires a great knowledge of electronics and equipment to read the chips in the key fob... and probably a few months of your life :?
I think it's safe to say that it's probably better all round just to buy a new unused remote and programme that.
Cheers.
x 1944
It's not that difficult.
This is the last time I'll say this but if you get the blade cut correctly and have a new ID46 chip then, with a Lexia or Diagbox, you can pair the virgin chip to the car.
uncle buck
x 10
Paul-R wrote:
cancunia wrote:Many thanks for the links, I've read through them and the overall view seems to be that the remote lock / unlock function is tied to a particular car and can't be changed.
No, it can be reassigned quite easily as long as the key blade and ID46 chip are working and recognised. This is where most attempts fail as they are trying to use an unrecognised key.
Paul-R wrote:It's not that difficult.
Are you understanding that we are talking about using a 2nd hand key to do this with?
We know how to programme the new transponder chip and fit it to a 2nd hand key....
We know how to get a new blade cut and fit it to the 2nd hand key....
So we now have a key that opens the doors manually and will turn on and start the car.
But how do we get the plip (remote locking) part to work on this 2nd hand key?
You seem to think you can just reassign it quite easily, there's a load of posts on the forum I linked to that seem to think different.
Care to tell us how you would do it, or have you said enough on the subject :roll:
Cheers.
x 3298
It may depend on the version of the car, but on my 2004 Xsara Picasso (company car) I had the engine running, and then pressed and held one of the key buttons (the lock one, IIRC) until the lock triggered. For this to work the car must 'know' the key (the immobiliser circuit) to allow it to accept the central locking remote functions.
x 1944
uncle buck wrote:Are you understanding that we are talking about using a 2nd hand key to do this with?
Yes.
uncle buck wrote:We know how to programme the new transponder chip and fit it to a 2nd hand key....
Then that's the difficult bit done.
uncle buck wrote: But how do we get the plip (remote locking) part to work on this 2nd hand key?
It's not hugely difficult and basically as Hell Razor says although you don't need the engine to be running and I think it's already been posted.
Turn the ignition on.
Press and hold the lock button for 5 to 10 seconds.
Then turn the ignition off.
Wait a few seconds and then try locking the car from outside.
Something I should have asked before (which you may already have said) is whether you have an already working plip remote? If you have and that works then it shows that all the bits on the car are working. There's always a possibility that the receiver on the car isn't working if you don't know for sure.
So, if this doesn't work then the technique is not at fault there's something wrong with the plip board or receiver on the car. The first item to suspect is the battery in the plip but after that it could be anything.
uncle buck
x 10
I'm not doing it I'm just reading the thread I believe it's cancunia that wants to do it.
We must be talking about different remote systems or something because it's all over the internet that it can't be done using a 2nd hand key. (by 2nd hand key I mean a key that is from a different car)
Yes you can do it easily with a new unused before key.
Have a read of the posts on the forum I linked to and you'll understand where we're coming from when we say it can't be done easily.
Cheers.
jgra1
(Donor 2021)
x 36
thanks all, I am reading with interest as I mentioned in my post earlier..
a good point from Paul, if this system isn't happy then it may fail anyway..
I will get on to this within a couple of weeks, if no one else does first ;)
John
x 1944
uncle buck wrote:I'm not doing it I'm just reading the thread I believe it's cancunia that wants to do it.
Sorry UB - It is a confusing thread.
uncle buck wrote:We must be talking about different remote systems or something because it's all over the internet that it can't be done using a 2nd hand key. (by 2nd hand key I mean a key that is from a different car).
So many people have tried to use a SH key without changing the ID46 chip that this chatter has obscured the truth underneath.
uncle buck wrote:Have a read of the posts on the forum I linked to and you'll understand where we're coming from when we say it can't be done easily.
The difficult thing is getting hold of virgin ID46 chips. In fact for a long time we didn't know for sure that they were single use chips. You'll see some five of more years ago when I started out on this that I was learning as I was going along. I also went down several blind alleys (thinking that the ID46 chip might be useable for three reflashes for instance) so it's no wonder that it's a minefield to follow.
