V6 pads
elma
x 284
V6 pads
Unread post by elma »
Are the front brake pads for the S1 v6 Xantia the same as for the s2? I can only find s2 ones and mintex website has no useful information.
x 1999
Re: V6 pads
Unread post by Stickyfinger »
if it has the larger brakes yes...(they all do I think)
x 1473
Re: V6 pads
Unread post by xantia_v6 »
Yes, all the PSA 288mm brakes from that general era use the same pads.
x 8423
Re: V6 pads
And also the 2.1TD, 110HDi (but NOT the 90HDi) and late TCT Activas - post mid 1998 - use the same 288mm discs and pads if the V6 is not specifically listed...
x 1999
Re: V6 pads
Standard Citroen OEM pads or the Mintex ones works best it seems for slow/fast road use.
