2 litre HDI smoking when cold
Harlequin
- x 24
Re: 2 litre HDI smoking when cold
ordered some new beru glow plugs from ECP - they sent me bosch duratherm... GLP013.
Harlequin
- x 24
changed fuel filter and glow plugs - stil smoking like a trooper!
- x 1746
Are the glow-plugs actually being powered up?
Test this with a test-lamp or meter at one of the GP terminals.
Harlequin
- x 24
all glow plugs tested - all heating up nicely
had a thought? since it goes away when warm - injector?
- x 1746
Is that when tested out of the car, on the bench, or when fitted to the engine and checked on the supply 'rail' that links them?Harlequin wrote:all glow plugs tested - all heating up nicely
Just want to be sure the glow-plug relay is doing its stuff.
Harlequin
- x 24
- x 1746
OK, looks like the preheating is working then.
The smoke and lumpy start only happens when cold?
What colour is the smoke?
How long do you have to crank the engine for, before it eventually fires up?
Harlequin
- x 24
fires up straight away, sounds like its running on 3 till `it clears its throat` so literally under a minute , if not under 30seconds.
smoke is grey/white
smoke is grey/white
- x 1746
Agree that the injectors should probably be looked at. I'm no expert at HDi systems, so someone else will advise here.
Might be worth running a strong dose of injector cleaner - Miller's Diesel Power Plus or Wynn's Diesel Treatment - through the system. Add to fuel at 1:200 for an emergency clean, 1:1000 for preventative use.
I assume you're not using supermarket fuel?
Harlequin
- x 24
c.morewood
- x 55
I never found out why my silver one did this when the temp got down to about 3C or lower. My cure was fitting a heating kit which raised the water temperature.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 1746
Hmm. What does Lexia say the coolant temperature is, Simon, when cold and compared to actual?
