A question about working on electric seats
elma
x 284
Unread post by elma »
Today I wish to tackle the non functional buttons on the drivers seat of my Xantia. Do I have to disconnect the battery before I start work? I'm not really sure how the pre tensioner system works but I'd hate to accidentally ground it. I will likely need to remove the seat, does this involve waiting 10mins with battery out then disconnecting the pretensioners or is there a different process?
x 6945
Re: A question about working on electric seats
Any work on the Airbag / Pre-tensioner system should be left until the battery has been disconnected for at least 2 minutes for the ECU capacitor to discharge - but I would suggest at least 10 minutes to be sure James.
They recommend not using an ohmmeter on the pyrotechnic devices and the pre-tensioners should only be held by the body, not by the buckle, or the metal cable. Good Luck :-D
ekjdm14
x 265
Unread post by ekjdm14 »
I've always tried to leave anything SRS related at least half an hour to be extra safe, but I do believe people "get away" with 10 mins or less so that should be sufficient. And, whether it's relevant or not, I avoid touching any of the electrical connectors in case of static discharge.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
elma
x 284
Thanks guys, seats fixed now. Was just dirty contacts so they didn't have to come out in the end.
