wiring damaged after using trailer?
Paulmi16
x 3
Re: wiring damaged after using trailer?
Unread post by Paulmi16 »
Aaaaaaaaagh Scotchloks!
x 3303
Designed by Lucifer, manufactured by Beelzebub, marketed by Satan!
x 1751
...especially if you get the wrong size one for the cables.
x 8343
Hell Razor5543 wrote:Designed by Lucifer, manufactured by Beelzebub, marketed by Satan!
Absolutely :twisted: Nasty, nasty and nasty...
Posi-Taps are better.. Still not perfect but a vast improvement on any Scotchlok...
Full range here:
https://posi-connect.com/
I use them where I cannot use decent crimps for whatever reason.
Here's a big black high-current one in use on Gabriel to supply her cooling fans bypassing the original open-circuit supply:
