Citroen C5 Maintenance Interval.
KP
x 27
Re: Citroen C5 Maintenance Interval.
Unread post by KP »
Personally I wouldn't stray from the correct size and rated tyres for a hydro citroen unless you need better tyres for track use or such!
As for servicing 20k is far too long even with fully synthetic oil! Our C5 is currently on a 6k service interval and every 3rd service has the gearbox fluid partially changed(you can only do about 3litres at once easily) and it had its cambelt, tensioners, water pump, coolant, aux belt & tensioner changed at 60k/5years. Again we think these intervals are far too long and only there as by the time it's reached the car is out of warranty and means it's no real risk to citroen for a warranty claim.
Oh and the best specialist in Cheshire imo is in stockport, Paris Autos. The owner has a C5 exclusive himself so knows them well :)
Sunderas
Unread post by Sunderas »
myglaren wrote:Yep, no bulb out indication in the early C5s.
I thought that mine being from 2009 it would already have it. Thanks for confirming this!
x 6957
@ Sunderas - Note: I've moved your Headlight Levelling query to a new topic to keep things easier to track:
https://www.frenchcarforum.co.uk/forum/ ... 67#p512867
