Re_setting diesel additive level on C8
- x 6945
Re: Re_setting diesel additive level on C8
It is possible Alan - the trouble is that PSA used a whole lot of interchangeable injection systems for their engines - so determining which one means trawling under the hood if the diagnostic won't identify it, but then if there is a problem with the board, it's not going to help much down the road with the other things either
wirdip
Hi Marc not attached before so let me know if you can see this
[img]screenshot1[/img]
Alan
Alan
- x 6945
No image Alan - you'll need to upload it to an image hosting site like Photobucket (basic accounts are free) and that will generate the IMG code that you paste back into your post.
There's a guide here - I will be updating it soon, but it will give you the picture (so to speak)
https://www.frenchcarforum.co.uk/forum/ ... hp?t=35470
- x 5672
No.
Alan, you need to have that image hosted on a site such as PhotoBucket.
Shout up if you need any assistance with it.
wirdip
Hi Marc, what a faff, I have been trying to upload image from an android tablet and it just kept failing so have fired up my pc and managed to do it from there. Lexia does global test, then onto injection which throws up this screen:
any help would be appreciated.
Regards Alan
any help would be appreciated.Regards Alan
Reason: Fix Picture
Reason: Fix Picture
elma
- x 284
You nearly got it Alan, I just had to redo the link.
When you view your picture in photo bucket theres four links to the right of it. If you click the one labelled IMG it will copy and you just need to paste that into your post. Hope that makes sense.
wirdip
Thanks for that James, is that on PC because it didn't do that on tablet.
Regards Alan
Regards Alan
- x 6945
Alan, I think you have the 2.0 RHM Bosch variant, as this is the code in your VIN.
wirdip
OK Marc will give that a try tomorrow and let you know what happens.
Thanks for help Alan
elma
- x 284
Yes it was by pc, theres a little grey chain button above the pictures as well. You should see it on a tablet, press it and the four links appear, IMG is at the bottom.
Hope your additive reset goes to plan.
wirdip
Hi guys. Made a bit of progress today. Got as far as after sales then particle filter then reinitialize of total additive amount. It then says read then delete the additive total quantity parameter, I tried all sorts of things but could not see how to do this. However I did manage to open the BSI ecu and the diesel additive ecu and had a root around in those but couldn't find any levels or amounts that could be altered. I also came across a help screen for resetting additive level which I will screen print tomorrow.
Regards Alan
Regards Alan
silvas72
HI.
I need reset diesel aditive in my Peugeot 308 SW 2.0 HDI 2010, but i dont have the number RPO.
My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
Thanks.
Thanks.
PaulC5
- x 696
The RPO will be one of the numbers on the tyre pressure sticker.
silvas72
My RPO number is 10402, but the site asks me for a code provided by technical support.
