ABS TOOTHED DRIVESHAFT RING ON XANTIA?
HDI
x 7
Unread post by HDI »
The offside ABS toothed ring on the offside front drive shaft on my Xantia HDI 90 has split and sprung apart, leaving a gap. So the ABS thinks there is wheel slip and keeps kicking in.
Has anyone ever changed one of these, if so what is involved. It looks like it would be an interference sliding fit. The rings are available on ebay.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1504
Re: ABS TOOTHED DRIVESHAFT RING ON XANTIA?
Easy enough: https://www.frenchcarforum.co.uk/forum/ ... 8&start=16
I'd give JandR CV joints a try - their parts are pretty good value.
ken newbold
x 4
Unread post by ken newbold »
I've welded them back on before now, just a couple of spots required.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
x 3298
CitroJim and I sorted out the rings on my Xantia a few years ago. It was a bit of a palaver, as we had to get the hub nut undone, and then disconnect a strut (I cannot remember which bit) from the hub so we could move it out of the way, remove the ring, clean up the drive shaft, and then fit the new ring (which had been in the over for half an hour at 170C) and put everything back together. Then we had to do the same for the other side!
x 8458
Easier and cheaper than swapping a whole driveshaft though James and then there's the fun and satisfaction of doing it. After all, it's not often you use a cooker for car repairs ;)
