Fuel pump
Taximan
Fuel pump
Unread post by Taximan »
Can anyone tell me if they have had an issue with there fuel pump in the tank like mine.
My car seems to struggle to drive like all 4 brake calipers are stuck on when a have more than a 1/4 of a tank of deisel in but anything under a 1/4 of a tank she flys along like there's no stopping her.
So am wondering could it be the fuel pump in the tank struggling to provide enough fuel if it's got to much in for the pump to send it out to supply the engine thanks.
Graeme
Sent from my iPhone using Tapatalk
Citroen c5 2.0 HDI
Year 05
Vin no : VF7**************[VIN obfuscated, can be read by forum staff] 76601045
x 1955
Re: Fuel pump
You've probably already told us this somewhere else but can you tell us whether your car does actually have an in-tank pump or it's one of the ones with a squeezy bulb in the engine bay?
I must admit that, even so, I'm struggling to come up with an explanation for this.
x 2008
Re: Fuel pump
Unread post by Stickyfinger »
Front disks grabbing ?? a well know @fault@ with the calipers on the C5 _01-08 cars
HDI
x 7
Re: Fuel pump
Unread post by HDI »
If there was a fuel system fault the engine management light would come on. Just wondering if the rear load sensor is somehow applying the rear brakes with a heavier fuel load?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Taximan
Re: Fuel pump
Thanks for the reply
It has got a pump in the tank.
You could be right about the front calipers but need descent weather to remove and clean.
As for as the rear sensor goes a don't have a clue about would a need diagnostics to tell me about the over wait sensor.
Citroen c5 2.0 HDI
Year 05
