Xantia full beam headlights not working
daviemck2006
x 485
Re: Xantia full beam headlights not working
Unread post by daviemck2006 »
It's not the car but in my house the centre ceiling lamp has 4 x 50W halogen bulbs. It was forever blowing bulbs. Since fitting a dimmer switch to it I haven't blown a bulb in 18 months. I always reduce the brightness before switching off so they are never off to full on.
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1997
Unread post by Stickyfinger »
OK another thicko question: will a supply/earth that has a fluctuating resistance shorten the life of a bulb ?
daviemck2006
x 485
Re: RE: Re: Xantia full beam headlights not working
Stickyfinger wrote:OK another thicko question: will a supply/earth that has a fluctuating resistance shorten the life of a bulb ?
I don't know the answer to that so I must be a thicko too lol
Peugeot boxer 2016
In the family
x 8422
I wouldn't imagine so...
It will just make it flicker and if the resistance is significant for the majority of the time it may even extend its life a little...
x 1997
Maybe then a result of low/poor power supply/ bad earths/ old "green" wires ?
x 5674
I thought I had a chart for Voltage vs. longevity but it wasn't.
Instead it is of brightness at increasing voltages - this is for halogen headlights.
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens
14.5V : 1528 lumens
x 8422
That chart shows why the S1 Xantia headlight relay modification is so effective Steve...
The difference in output with just a small voltage reduction is really quite staggering!
