what part is this?
Harlequin
x 23
what part is this?
Unread post by Harlequin »
so chaps - what part is the one in the middle? it has warm air blowing out and the air flow is engine speed related.
x 6948
Re: what part is this?
A VIN might help.
Harlequin
x 23
I`ve searched on service citroen but cant find it
v7x1dhxk72055738
x 6948
I just can't make it out from this photo - maybe if you took a picture further back so we can see it in context with other components.
Harlequin
x 23
Xantia 1.9 td . Pipe on the right is the intercooler to intake , pipe on the left is turbo to intercooler. Small rubber pipe in middle leads to fuel pump
x 6948
I would say it looks like a vacuum control purge valve?......
https://shopcar.parts/en/autopart/19570 ... urge-valve
Harlequin
x 23
part 11 is the bottom end of the small hose in the centre of the picture - and that's the hose I cannot find any other reference of
x 6948
That just doesn't look like the same part to me Simon, wouldn't Part 25 be the hose in my diagram (you can just about see it as the last item on the table?
Harlequin
x 23
i`ll make a video tomorrow to show it - the input side of the electro valve in the photo is warm / hot air from the turbo > intercooler pipe and the other end connects to the fuel pump
Harlequin
x 23
Think I need sleep. YES 1628CH looks like the other end of the part I linked.
Is it for the fueling when the turbo is on boost?
x 6948
This was listed under the Gas Recycling Circuit Simon - and looks just like the part in your other post:
https://www.frenchcarforum.co.uk/forum/ ... 94#p499254
Harlequin
x 23
its slightly different - the EGR is avacuum driven whereas this sint (its turbo boost )
x 6948
No worries - at least I think you have identified it now :-D
