Is my mechanic on the right track
x 1238
Re: Is my mechanic on the right track
Unread post by Peter.N. »
That will be 'no' then :wink:
harryp
(Donor 2022)
x 73
Unread post by harryp »
Sadly looks like it, lol
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 1750
Harry,
If the car goes to a height higher than Normal (when Normal height is selected), then there must be a reason for this. Usual cause is height control rod/lever mechanism out of adjustment or sticking, or height corrector (assuming its hydraulically ok) getting incorrect mechanical input from the suspension/roll-bar linkage.
My hunch is that something is sticking when the car goes over-height, and this unsticks itself, causing the car to drop to Normal level.
Paul02
Unread post by Paul02 »
Hello Jim could you give me the name of some of these specialists that you mention please as had a ring around and can't find anyone who wants to touch it or who knows about em . If you don't want to advertise on here then send me a text if you can on 0-7-9-7-4-0-9-7-6-5-3 thanks Paul
Reason: Break up phone number
harryp
(Donor 2022)
x 73
Thanks for response chaps, will have to bite the bullet and reset the running height...
Regards, Harry
x 1750
Good Citroen specialist at Dunsfold (nr Guildford), if that's not too far from you. I can post details.
Paul02
Cheers Chris please do
elma
x 287
Unread post by elma »
I wonder if it's just case of the height corrector being adjusted incorrectly. Did this behaviour start suddenly or has the car always been like this?
I've had 3 antisink Xantias so far and all of them have slightly sunk at the rear when left overnight. Assuming you have checked the returns and the accumulator spheres already I'm questioning if yours just behaves normally but drops a little more noticeably because it is set too high.
x 1750
They are
SGG Dunsfold Park Garage (at Dunsfold, on the A281, a few miles from Guildford), 01483 275971.
Were previously Shalford Green Garage, a Citroen specialist independent, and know the lot, DS onwards. Good website.
Actually on Dunsfold Aerodrome/Top Gear track. Temptations, I know...
x 5587
If you have personally used them and been satisfied Chris, the a post in the "Recommended Garages And Services" forum would be welcome.
harryp
(Donor 2022)
x 73
Thanks James. If you wind back a little you will see it started after I had cleaned and reset the HC and cradle, so although it was carefully re-assembled back in the same location; maybe not. The puzzle was it settling overnight to the correct height and no further. Nevertheless, it will be reset before I put it back on the road. Thanks to all for input; much appreciated :) .
Regards, Harry
chinkostu
x 30
Unread post by chinkostu »
elma wrote:I wonder if it's just case of the height corrector being adjusted incorrectly. Did this behaviour start suddenly or has the car always been like this?
Sometimes if my cars been on HIGH and then back to normal it will sink down a few hours later. Day to day it seems to only drop a tiny bit, so wether sticking it all the way up is pulling air in! regardless, it'll pump back up when started to the correct height.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
harryp
(Donor 2022)
x 73
No change in setting required; that's the way it goes - will do a height reset.
Regards
Regards, Harry
