x 1996
Re: I am an Activa owner...a V6 and I am an addict
Unread post by Stickyfinger »
I was surprised to be honest Jim, I have not touched it for ages and ages, it has held its code and once the fuel was pumping (I have had the pump out remember) she fired up fine.
STOP lamp off after about 15 secs,............bonus.
I want to move it out of the way because I have a Cam-Belt and a Gearbox oil change on the C5x7 to do soon, it is currently parked in my "ramp" bay and needs to become a security-by-blocking car for the winter :)
x 1996
I will cut here.
Using a Dremmel and a large cutting disk I removed the top.
Ones the mounts are set up and metal supports are in place, the top part will be replaced and blended with windscreen sealant and finished to look like it is original.
this allows access to the top mounts and will give the few mm of needed clearance.
(glass will be replaced with clear thermoplastic blow down sheet)
x 8415
Coming along a treat Alasdair :D
I expect to see a working prototype on Thursday ;)
x 1996
More layup/checking on positions etc.
x 3296
Just a thought. Why not use fibre optic 'pipes'? I have seen some EPoS units (mainly those made by Par) that have the status LED on the system board, but with a flexible length of plastic (about 1/8th inch thick, and 6 inches long) going from that LED to the position on the casing where the light appears.
x 1996
It all looks a little "rough" at the moment, but it is all just in temporary materials and hand cut.~
Re: LeD and Fibre optics, I have been thinking about this to replace the DRL's with a pair of brightly illuminated chevrons :)
x 1996
Favourite photo from the summer
x 1996
Well that looks nice !
x 8415
Stickyfinger wrote:Well that looks nice !
They both do Alasdair ;)
x 1996
Well, both lamp units do fit (just !)
Mounting method is worked out and will be easy and will also be secure/preserve the OEM look.
Now onto getting the mounts cut neatly/correct thickness of ally, eg NOT with my angle grinder :) and onto the glass replacement.
Dip is inside the main so as to allow good spacing/vision of the indicators
daviemck2006
x 485
Unread post by daviemck2006 »
Here's how yours would look!
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1996
Giving me ideas there Davie :)
More work on the headlamps.
I have now worked out how to reuse the original headlamp inner chrome trims.
x 1996
With added Citroen Logo
x 1996
using foil to simulate a possible finish
x 8415
Looking a proper job Alasdair :D
