C5 mk 1 starting problem
x 1240
Re: C5 mk 1 starting problem
Unread post by Peter.N. »
wurlycorner wrote:8-[ 16.4? Thats a bit high?!
Sorry that should have been 14.6. :oops:
x 6947
hirsty wrote:How do I reset the auto lights function?
hirsty
Switch ignition off, press in and hold end button on the trip reset stalk (I think this is the left hand stalk, but can't be sure, it's been a while), then whilst holding the button in, turn the ignition on, keep button pressed and you should hear a 'bong'. Same procedure to deactivate.
x 5675
IIRC you press the button at the end of the stalk then turn the ignition key to the second position - there should be a confirmation message on the infoscreen.
Note that it isn't always necessary, autolights often just work without intervention.
I'll look it up in the manual and confirm but don't have it to hand at the moment.
x 1056
Unread post by wheeler »
hirsty wrote:The current battert is 19 months old and is a Lion 100, 70Ah, 620cca.
I see two problems here, first its a euro car parts Lion piece of rubbish, i am amazed you have had 19 months out of it.
Secondly a 100 battery is way too small for your car. The original C5 battery is 720cca(EN) however most battery catalogs list the 2.0 HDi battery as a 096 which is around 650cca (EN).
When choosing a car battery the CCA is the most important number.
hirsty
x 9
Unread post by hirsty »
Hi Wheeler,
I have now received the Varta E44 which is 77ah and 760 cca. I will see how it goes in the morning.
hirsty
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
x 1240
Actually it should have been 14.4 volts, my mind is going. :?
hirsty
x 9
The car started fine this morning with the new battery. I have had the car into a well respected auto electrician who said "alternator fine, starter fine, no leakage of current. Two dead glowplugs." I thought these didn't come on until much lower temperatures than currently, but I intend to have them replaced anyway as a precaution.
hirsty
x 3296
I have helped people (via this forum) who had starting issues that turned out to be the glow plugs. Ask the electrician if he removed the glow plugs to test them. The reason I suggest this is that it is possible for the glow plugs to fail in such a way that they still heat up, but NOT at the tip (as required) but halfway down the element. It might be worth replacing all four glow plugs.
hirsty
x 9
I have already requested a quote for the renewal of all four glow plugs as it is not getting warmer anytime soon. They look to be around £20 per set. I submitted an email address to GSF and received a 30% discount code by return. They were NGK. Are these any good?
hirsty
x 1240
They used to make spark plugs so they should be.
x 5675
Beru plugs seem to be the ones most recommended for PSA engines and are OEM
wurlycorner
x 271
Unread post by wurlycorner »
ngk are a good quality make, ddon't worry.
Iain
CX DTR T2 Safari (silver)
hirsty
x 9
Looking at a previous post, the glow plugs don't operate until 0 degrees C, so that isn't the current problem. Starting this morning took longer than usual with the starter turning slowly, although it did start. I am looking at changing the starter motor and checked out GSF for prices. Entering my reg throws up 3 starters. All listed as 2.0 HDI 2001-2004
1.8 kw @ £178
1.4 kw @ £196
2.3 kw @ £355
The BOL is as usual useless in identifying which I need.
Any suggestions please.
hirsty
x 6947
Post up your VIN and I'll check in the morning for you.
waynedance
x 8
Unread post by waynedance »
myglaren wrote:Beru plugs seem to be the ones most recommended for PSA engines and are OEM
Been told the same (work at a garage) and from what I remember the glow plugs on my C5 do nothing until its -5 degrees.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
