Play N/S front wheel
Rhothgar
- (Donor 2026)
- x 222
Hi all
Been a while.
S2 Xantia failed MOT on wheel bearing *DANGEROUS*
Changed it but there is still play when holding wheel at 12 and 6 o'clock and 3 and 9 o'clock.
Can't find any reference to this kind of problem on the forum. I can't be the first.
Been a while.
- x 1240
Re: Play N/S front wheel
Are you sure the play is in the bearing and not the ball joint? If the bearing is moving it could be that its not been adjusted correctly (I believe these are taper roller bearings). There always will be a small amount of play to allow the grease to circulate but it shouldn't be excessive, you will certainly feel it though.
Rhothgar
- (Donor 2026)
- x 222
I am sure that there is NO play in the bearing because I've changed that.
Doubt it would be the ball joint as the play was noted on the MOT as wheel bearing excessive play and the offside ball joint was picked up.
The bearings are not tapered on Xantia S2.
- x 1240
Can you not see where the movement is? Other than the bearing being loose in the housing I can't think of anything. Have you got someone to rock it while you look underneath?
- x 3298
Silly question, but how does the wheel feel if you turn it by hand? I have once spun a wheel that had such a bad bearing it felt like it was rumbling on gravel!
Rhothgar
- (Donor 2026)
- x 222
Bearings brand new Hellrazor as previous post so bearing not the issue.
Can't see where the movement is other than at the wheel. Bearing was passed out and in so no play here.
It's clear that the bearing didn't need changing after all.
- x 1240
Does it move from top to bottom or side to side or both?
Rhothgar
- (Donor 2026)
- x 222
Yes it does Peter. All as per original post.
- x 8457
How odd..
Did you change the bearing or get a garage to do it?
Rhothgar
- (Donor 2026)
- x 222
I went up to my mate's garage Jim. He changed it but afterwards was as perplexed. He asked me if I had taken anything off that side in the past.
I couldn't remember.
I know two CV boots were ordered a couple of years ago.
Problem is all parts generally get attributed to the same car even though they might not have been fitted to that car.
Why, what are you thinking?
- x 8457
Just wondering if who did the job noticed anything odd like the bearing being a too-easy fit in the hub or the stub axle too easy a fit indicating something might have been cracked or damaged... A bearing should be tight and take at least a couple of tons of pressure to seat it in the hub and the same for the stub axle.Rhothgar wrote: Why, what are you thinking?
Some things I'd check beyond the bearing...
Are the driveshaft splines OK? Again they should be a tight sliding fit in the stub axle with no play, even with no hub nut fitted..
Is the CV joint body correctly sitting on the inner bearing race face? Hub nut done up FT and a bit?
It's not being confused with P Bush or front wishbone bush wear is it? A P Bush can look good but give rise to exactly the symptoms..
Bottom swivel joint and track rod end OK are they? Both may need disconnecting to check but the person swapping the bearing should have noted any oddities with those...
It's not just a loose brake disc is it? Wheel off and using the disc as the lever and hand-hold to check for play could well give a confusing indication if the disc is not securely attached to the hub say, because its Torx retaining screws are loose or missing?
I'd love to look and see for myself as it's a real perlplexer...
Do let us know the outcome...
If all else fails, might be easier to swap the whole hub for a known good one if the fault does not give itself up easily...
Rhothgar
- (Donor 2026)
- x 222
Thanks for that Jim.
What a full reply! As soon as I am in front of a PC a again, I'll give it a full answer rather than typing with two thumbs on a phone.
Thanks again.
Thanks again.
- x 8457
No worries Roger
Very happy to try and help here and very intrigued...
- x 1061
Is it a Euro Car Parts wheel bearing you fitted
Paulmi16
- x 3
or Sutton Auto Factors/Discount Autospares
