Forum promotional cards / stickers
x 6945
Re: Forum promotional cards / stickers
Ok, you'll have to take my word for it that these look a lot better with the enhanced text and logo outlines than they do here - I make no apologies for having super shiny windows ( :sun: ), but on this occasion there is so much reflection that it is affecting the shots! Hopefully, you can see that the text and logos look better against the white of the flag, but these pictures don't do them justice I'm afraid.
Well that's my David Bailey number for today! :tgif:
superloopy
x 19
Unread post by superloopy »
Marc ... what are the eventual sizings of the rear/door stickers?
Mike
x 6945
xantiamanic wrote:Marc ... what are the eventual sizings of the rear/door stickers?
Ok, so the Disc is 7.5cm x 7.5cm (to enable fitting inside an old disk holder) and the rear window sticker hasn't changed 5cm H (1.97") x 25cm W (9.84")
I didn't do a separate side door sticker - but easy enough to do so if required. :-D
x 3565
GiveMeABreak wrote: Well that's my David Bailey number for today! :tgif:
Très bien !
Me likey :)
x 1746
OK by me. The strengthened outline works really well on the white.
Formidable, mon brave!
superloopy
x 19
Can people give an opinion on the overall sizing of that rear sticker.
Personally I think at nearly 10" it's a tad on the long side that's all ...
Mike
x 6945
I think once Jim has an idea of the dimensions for the media, we can adjust the rear one to suit easily enough.
x 8412
Try the size Russ originally recommended perhaps?
x 1994
Unread post by Stickyfinger »
80mm x 80mm Square ?
x 8412
Robyn's 207 is possibly the very first car ever to wear an FCF sticker... Her old tax disc holder now sports a paper print of one of Alasdair's stickers :D
x 6945
I just noticed this morning that the design I've been working on has the Logos back to front from those on the Forum!
So can you please let me know if you are all ok with having Citroen on the right (which compliments the red and silver of the logo in a way) and Peugeot in the middle, with DS where it has been. This will also serve to distance DS from Citroen as a brand in keeping with PSA.
Can you please let us know if you are happy with this change - personally, I think it should flow with the main FCF banner as it is at present (although I realise that DS isn't currently incorporated into the design).
x 1994
working along the theme
x 6945
Definately has that je ne c'est quoi factor Alasdair! :-D
x 1746
GiveMeABreak wrote:Image
I can see that we ought to match up the new stickers with the Forum masthead.
But I think the design above should revert to previous
- Peugeot lion nicely facing inwards
- Citroen and DS together (some logic to this).
If felt a good idea, then it might actually be worth changing the order of the Forum masthead logos, to match this.
x 1746
Marc,
