Brake disc life?
HDI
- x 7
Re: Brake disc life?
I unashamedly admit to being a heavy footed driver, I just like to make progress. I use gears AND brakes but try to maintain as high a corner speed as possible! I do try to avoid slowing or stopping unnecessarily, like anticipating flow at roundabouts etc. If I had to pay a garage to service the car though, I might adopt a different driving style! I've found that cars with rear discs suffer from brake corrosion if driven very moderately. This latest Xantia I'm using had semi seized rear brakes when I first got it and it felt very under braked. The rear discs were very rusty, especially on the inside. After about 500 miles with me behind the wheel they have freed up noticeably, the brakes feel much better and the rust on the inside of the discs is being removed.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
qprdude
- x 14
Yes, you probably brake 100 times more with an hours city driving than an hour on the motorway. OK, Motorway braking is from higher speeds but still much less wearing I would have thought.bobins wrote:I think it helps that I do a lot of long distance driving !!![]()
Not that it's much of a comparison, but my pick-up truck is only on its second set of pads and second set of discs (the first ones warped) and it's at just short of 100k. There's still plennnnnty of meat left on the pads
Rick.
2013 Citroen DS 5 D/Sport
qprdude
- x 14
Well that's it done. The mechanic took 2.75 hours. Oil and filter replaced, levels checked and topped up (Antifreeze added) Wheels off, brakes cleaned blown out and lubricated. Tyre pressures checked and adjusted. Total cost £109 . 50p.
Fully synth oil and OEM filter.
Plenty of meat on all pads . Rear discs showing a little wear but nothing to worry about.
Belly pan condition a little worn looking ( Mine and the car's) but OK.
Happy? You betcha!
Happy? You betcha!
Rick.
HDI
- x 7
Thats a very fair price and you have piece of mind.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
daviemck2006
- x 485
Thats a decent price for that. You know it will be well for a blast up the country.
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
qprdude
- x 14
Yep Davie, looking forward to a DPF regen.
Rick.
