ecu reset
- x 1480
Re: ecu reset
No radio code required, but this won't re-set the fault codes - you need a tool for that (preferably Lexia/Diagbox). If, however, you have fixed the fault, then the light should go off after a few starts, although the fault may well remain in the memory.
Mellorj
Re: ecu reset
Hi i had a 1.8i 53 piccaso the radio is vin coded so you will not lose code
