Easy HDI Xantia Water pump change
John Plum
- x 5
Hi folk,
Is it possible to fit a new water pump without locking the crank and removing the auxiliary belt?
I mean, could I simply remove the top cover timing belt cover and release the tensioner, then fit a new water pump?
John
John
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
OnlineRichardW
- x 1504
Re: Easy HDI Xantia Water pump change
I don't think so, because the water pump is under the lower cover which needs the pulley removing, and in any case you will need to remove the timing belt, and I doubt you can do that with the crank pulley in place (well, not without wrecking the lower cover anyway).
John Plum
- x 5
That's what I suspected. OK, I'll start on the preparation strip down straight away.
Thanks Richard.
John
Thanks Richard.
John
John Plum
OnlineRichardW
- x 1504
It's not too hard a belt to change - the 90 is easier than the 110 as there is less in the way at the top.
John Plum
- x 5
I've commenced... its just getting round to it that takes most time!
John Plum
- x 8462
Change the cambelt, aux. belt, jockeys and tensioners whilst you are there John
Shame not to whilst all is in bits and given they all have to be removed to get at the water pump anyway...
False economy not to.
John Plum
- x 5
Righto. Definitely will Jim.
By the way, is the TDC on the flywheel found approximately, when a small hole on the crankshaft pulley faces Straight up (in relation to the engine at its slant), on the HDI ?
John Plum
chinkostu
- x 30
you normally lock the crank off with a pin at the flywheel end, theres a hole it will slot through and into the block, and then there should be a hole you can put a bolt into for the cam. the pumps don't need locking off thankfully (unlike the older diesels)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
OnlineRichardW
- x 1504
Info here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=33939
Timing point for the cam pulley is at 7 o'clock, this should match with the timing hole in the flywheel....obviously!
John Plum
- x 5
Of course, I realised just after I posted... I don't need to align the crank first, align and lock off the cam shaft and then just stick pin the crankshaft, as it will be ready aligned, assuming I haven't removed the cam belt. So, timing covers off first.
Is it OK to yank free the crank pulley nut with the flywheel pinned, do you reckon? I can't loosen it with car in gear.
John Plum
chinkostu
- x 30
Bodgey way of doing it is brace the breaker bar against the floor then crank the car on the starter (WITH LOCKING PINS REMOVED FROM CAM AND FLYWHEEL!!) which should force the bar into the floor and crack the bolt off.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 5688
John Plum
- x 5
Got the top covers off - much easier than the XUD, I have to say, getting at the cover bolts!
Too late for the starter motor method - I've pulled mine out of the way. I'm going to wedge the flywheel and use a socket and breaker. ... Which worked nicely with a short piece of strong tube over a t-bar (i.e. in order to get enough room for a turn, i couldn't use a long breaker bar) + a good old British forged masonry chisel as a wedge,
The rest should be straightforward.
The reason for the water pump change is that it is leaking - due no doubt to fans failing to come on in traffic, due to failed radiator fan motor.
John Plum
- x 8462
I believe, when the engine is pinned for timing no pistons are actually at TDC but a little way down the cylinders to guard against valves potentially kissing piston crowns when work is in progress...
John Plum
- x 5
SO I seem to remember reading, now you mention it.
I've been looking for a threaded receiving hole to pin the camshaft, but can only find a hole without thread - perhaps the scheme of things changed for the HDI, so I ask Is this the right pin hole, any about 7 to 8 o clock?
Answer: Yep, that's it ... no longer a threaded hole to receive your 8mm pin, on the HDI.
John Plum
